Longgone
John/68 Barracuda & Dart
Has anybody installed the new LED lights in place of the stock push in bulbs? If so do you have any before/after pictures?
Nice! Are the bulbs in the Sun gauges the push-in 194/168 style? You say you found them at Advance?
The ones in the sun guages and the gear indicator
were single little LED's with 2 wires running off each (+&-)
4 to a pack, white,red,blue or green I think bout $11.00 Advance.8)
The ones in the dash instrument panels were push in style like stock but LED, see whiteguages.net
whiteguages.net8) Love this company!!!
Sorry first 2 are white face & LED's blue (The 3 round under dash "SUN" guages & gear indicator are LED's from Advance 4 singles to a pack.)
2nd 2 pics are white face with painted 2 tone back plate with stock bulbs.
Hope this helps!8)
http://www.dieseltruckresource.com/dev/diy-led-gauge-cluster-lights-t201732.html?t=201732
http://www.dieseltruckresource.com/...nt-cluster-install-leds-t209884.html?t=209884
http://www.dieseltruckresource.com/dev/led-turn-and-tail-lights-t166797.html?t=166797
http://www.dieseltruckresource.com/dev/update-1st-gen-21st-century-t100449.html?t=100449
http://www.dieseltruckresource.com/dev/fusible-link-abatement-t135504.html?p=1407509
http://wiki.dieseltruckresource.com/wiki/Tech_Articles
Why did I post a Dodge diesel truck page as a resource? Because even though the part numbers might not work, the tech ideas will. This is an excellent source of tech stuff. Hope this helps!
The first 2 links relate directly to led dash conversions, also listed are tail light/turn signals, exterior lights and replacing fusible links. That ought to help out here if the rest won't!
Alan
I ordered mine from superbrightleds.com & am pretty happy so far.
I used the WLED (194) Type, which is a direct replacement for the old bulbs.
They have a good selection & their prices look pretty competitve (if not a lot better) than regular bulbs - for example, their dash bulbs range from about $0.79 per bulb up to $2.99 per bulb. I haven't put my bezel back on but these seem to have illumination at a much better level than the old style bulbs.
the next chance I get, I'll replace all the exterior bulbs as well.
WoW! That gives me hope because I just got my decals for the gauges recently from the same company. Question: Did you have any install issues? It seems pretty straightforward...kinda like the decals found in scale-model kits.
Anyway, your's look incredible.
do you have a exact link and name of the exact light you need to buy for a duster? also how much were they. thanks. can you also put them in autometer guages too?
