dartslantsix
I have a couple questions as I'm hooking everything up to my 94 318 Magnum. I'm using the serpentine drive as well- out of a Grand Cherokee.
First is regarding the lower radiator hose. My car is a 67 and has the radiator inlet on the driver side while the pump side is on the passenger. Has anyone run into this and how did you solve it? I'm thinking I'll have to make up a metal tube connected by rubber elbows.
Second question is regarding power steering. I'm using the stock power steering gear and the pump is the Jeep Grand Cherokee style (not sure if this uses the same connection as the truck pump). What line fits? I think someone mentioned the Diplomat hose- will that work?
Thanks in advance.
Thanks in advance.
