Hyper_pak
Old School Chrysler Fan
Aluminum Slant Six Timing Cover with window to change timing on the cam shaft.
Your right.....I do have a 63 standard dash somewhere.....need to post this metal plate - 3"x1" - think it might be a 1962.The texture is different in the bezels.. And the 63 4 speed cars it's not a plate, but the dash itself
No 63 4 speeds not until 64, but I bet you meant to type 3 speed.The texture is different in the bezels.. And the 63 4 speed cars it's not a plate, but the dash itself
FixedNo 63 4 speeds not until 64, but I bet you meant to type 3 speed.
Some one is reproducing them.How about left (and right) exhaust manifold gaskets for 67-69 340. Metal gaskets with spark plug wire protector on the left side. I don’t have any but sure could use a set
Short answer...Okay. I am openly and totally admitting that I am new to this. I don't totally, nor quite understand this technic. Can you explain it better than wapitikia (sp )? I have some hard to/ can't find / they don't reproduce parts that I'm looking for and many follow me in the same pursuit. So I can bring you more. Thanks
T-10.........No 63 4 speeds not until 64, but I bet you meant to type 3 speed.
