joes68340s
The 8 inch converter was built for the bigger motor. Im not planning on changing the converter for this setup.
…..see if it will take more rpm as im only shifting 6600.
Agree! Depending on trans shift time, and internal reaction time , can be up to four or five hundred rpm..If your “shift light” is at 6600, you’re actual shift point may surprise you. The time between “see light”, “pull shifter”, mechanical time to make shift is quite surprising
