Normal. It seems worse with Edelbrock carbs. Probably because the float bowls are part of the base and the puppy pee gas now days evaporates easily. A small electric pump with a momentary switch seems to work well. I thought I had bookmarked a post with a electric pump number. Can't find it. Oops, mderoy has the number in the post above.After the car is parked for several days I have a hard time getting it to start - like no fuel.
After I crank it for a while and pump the snot out of it it will fire and run normal. Somehow it is losing fuel.
I am running an LA340 with Edelbrock 1408 carb with electric choke which is working and a Edelbrock mechanical fuel pump.
All appears normal and it only does it after it sits for several days.
No hot start issues
No run issues
No gas in the oil
No fuel on the ground
No leaks that I can find anywhere in the fuel system
I dont believe it is boiling out of the carb I use a thermal spacer between the car and manifold to prevent this.
Is there any way it can siphon back to the tank?
Im lost
