Right you are. Sorry for the misinformation. I corrected my post. I either need to build more engines or not rely on my memory as much. LOL tmm
No problem.
I had to go look myself before correcting you so I didn't make a mistake also. :banghead:
If there was water, why didn't the ice go up instead of forcing the plugs out..
I realize that it is now a moot point but I like to understand the whys....
We are very disheartened.. we worked on it for a 3 hours yesterday. We just don't have the heart to pull the engine again..
When rebuilding my engines for racing, I never bother pulling the plugs out after the first re-build; I keep the fluids clean, don't use straight water for coolant (this is rally, not circle track) and thus avoid rust, and don't worry about anything getting in there after the first go-around. I suspect the prior post presenting the same idea was in regards to race enigne rebuilds every season or more often.
We used Loctite on the block machining line that I was responsible for. It made a huge mess eventually that maintenance had to go in and clean regularly. If we didn't need loctite in the core plugs, then they wouldn't have done it. They would have saved alot of money to remove those stations from the line.
I would use loctite or some sealer on the cup plugs.
Yup--the OEM's figured it out long before I did. Loctite has SEALING properties, especially the sleeve retainer I like to use. Silicone is SLIPPERY. Some people just can't use logic. J.Rob
This sucks I know, but unfortunately Ian, you are probably going to have to.
It really might be best in the long run to pull it and replace all of the larger ones and inspect everything real good.
