moper
Actually you should not need any sealant at all if the plug bores are in good condition. I used to use sealant till I had a couple of plugs blow out in a circle track application. Racers get angry when they have to get off the track due to scorched feet and over heated motor. 2 separate incidents and I started using Permatex Sleeve Retainer--That was over 10 years ago. Many many frost plugs and cam plugs later not one leak and not one blow out. I think I'll just keep doing what I'm doing. J.Rob
I've always used a very thin "skin" of sealant on them and make sure they're in far enough to clear the bevel. I haven't had any issues with leaks, seaps, or popping out but I know it's more common when using brass plugs. The old manuals had instructions for retaining straps for them in circle track apps.
What happens when you try to remove the plugs to wash the block? Do you have to heat them?
