chrisnben
MR Badfish
For Sale: NEW 470 Stroker engine- minus heads & intake ('73 400 block) zero decked, align honed, bored .035, 440 Source forged rotating assy. (-17 dish pistons, H-beam rods, 3.915 crank) balanced; Comp Cams solid cam & lifters (252/260 @ .050, .541/.559 lift, CL at 106, 110 sep.) Comes with 7 qt deep pan with baffles & p/u, Melling HV oil pump, Rollmaster 9-key timing set, valley pan, front cover, ARP main & rod bolts, 440S fluid dampner, aluminum WP & Mopar housing.
These 470's think they are a 383- still wind up hard! Should make an easy 575-600 HP depending on your heads and rocker ratio. (C/R is 10.25/1 static w/ 80CC head & .039 gasket). Assembled- ready for shipping. Located in Sun Prairie, WI. Shipping available. More info by request. PM me here, thanks. Save some time & money. $3999.:burnout:
