Mad Dart
Nothing to see Here!
Old thread. I'm still using cheap Oreilly mounts, but I added a solid link similar to the Shumacher strap that you guys can get. So far so good.
Sort of the same thing as running a solid motor mount on the drivers side if the strap is mounted solid on both ends. I would much rather see the strap on the block instead of the head especially on higher HP Applications to keep any shock, force or movement away from the head gasket.
