66durgederp
"pull hard, itll come easy"
So i posted this in the early a-bodies forum but thought afterwards this would be a better place to ask, sorry about that. Im just checking myself here and would like a couple pointers if needed... So yesterday was gran fury destruction time. surprisingly it came apart like butter. searching through numerous threads i found the measurements of the posi 8.25 from the fury, vs my 7.25 posi currently in the derp.
8.25 Dippy/Fury "M" body:
Flange to flange- 54.34 inches.
Perch center to perch center- 44.46 inches
Center line of axle shafts to centerline of u-joint- 11.69 inches
7.25 derpadurp early "A" body:
Flange to flange- 53.2 inches
Perch center to perch center- 43.02 inches
Centerline of axle shafts to centerline of u-joints- 10.09 inches
so to shorten the driveshaft i would need to remove 1.6 inches, right? or is there some drivetrain geometry trick or calculation or driveshaft measuring anomaly im potentially missing?
I know id have to move the perches in .72 inches per side as well, however my biggest question is, since my 66 hasnt been mini tubbed or anything, would it be safe to say if a 15x7 with 4 inch backspacing fits like a glove for a stock setup, if theres .57 inches additional per side, then a 15x7 with 5 inch backspacing should be the cats meow?
Or are the extra .57 inches per side going to cause some headaches? thanx guys!!
