If it turns 5000 revolutions per minute, how long does it take to turn 5000 times?
Wait wait, this is a trick question right? Damn it my head is hurting. That would make it undersized right? Or oversized? Aw hell I give up!
Its a street car, very little track time. 340 Stroked to 416. Shooting for 550-600HP 550 TQ. Will be Dyno'd. Eagle forged crank, recently balanced, polished and chamfered and apparently no one checked my clearances worth a crap. Glad I did my own plastigauge. This car will see 2000miles a year at most. Show quality resto, but still a driver for local cruising. I want to see .002" for clearance, I think that will be a good number to shoot for and for sure the .001" I have right now aint going to cut it. Redline will be 6800-7000. Oil will be a good quality 10-30 to start and later going to royal purple synthetic 10-30 as well. Oiling is via HV oilpump, oiling mods on sticky in this section done but I went with the bushed lifter bores.
Mics are cheap.
yeah instant 30 thousand miles the quick way.......Thts what happens when guys assemble motors too close to the blast cab.:happy1:
Bearing clearance is the result of the bearing bore, the bearing shells, and the crank surface. Without a mic and measuring you can't tell which might be causing it. this is one of the issues with plastigage and why if you're serious (and it sounds like you are) then buying the right tools can only help. You're beyond the "street engine" power levels and thigns have to be right, not "ok". In any event, you should be able to get the bearing shells to get the clearance you want. But if it was me, the shop should mic the bearing bores and the crank while you watch (pay them for the labor) and then you can see how it should be done.
Questions;
Does anyone think that 110 torque PLUS 90 deg is a little snug for main bolts?
Are you oiling the bearings before checking clearance?
Are the other mains installed and torqued?
Have you checked with crank in another position?
just curious... what brand of bearings did you get
I just paid $4500 at the best machine shop in a 500 mile radius. So I was expecting way more then "ok". I was expecting perfect, and even though I was told by them to just go ahead and assemble I wanted to check clearance myself even if only with "poormans plastigauge". So I am pissed and I will be having a serious discussion with them Monday morning. There will not be any more $$$$ coming out of my pocket as far as this ckearancing issue goes.
Questions;
All caps have to be fitted to the block, and then the main bores re-cut and honed. So that's all normal. I'm just curious why the crank would be re-polished. My money's on the main bores, but I am curious about the condition of the crank. I'd definately want to be present when they do thier measuring.
When you use platigage all surfaces MUST be oil free, oil will give you a false reading.Not to sure, the whole rotating assembly was balanced, anything to do with that? I'll be on the phone tomorrow with shop to see. How do most guys check clearances, with bearings dry or a light film of lube? I don't think torquing dry would be good? I put a miniscule film on top bearing and and nothing on cap bearing. I also have .008" play at thrust bearing.
I checked all my rod bearings today and I have .001" to .00125 clearance on those. Too tight as well. Torqued to 63 ft/lbs as per Eagle specs.
I have only had 2 pistons in at once at the most because I have clearance issues at the Stud girdle and rod bolt to bottom of cylinder, not all but I need to do some clearancing yet. But with 2 (no rings) in I can turn the crank super easily, no binding or seeming tight with the thou of clearance I measured.
