I bought a 76 duster steering box to replace my worn out 69 V8 dart one what do I need to get this to work ??? is It worth the cost ? Told 16:1 ratio 3 turns one side or other .. :banghead:
There is a pitman arm issue not matching the drag link.
Here is the information and a link for the OEM box for your car. I know that you are asking about a 76 box but I don't have that information. Someone will chime in.
The optional on any 66 to 69 A-body Fast Ratio 16:1 steering box is 3.6 turns lock to lock.
I already installed the box then a new pitman arm and 75 duster drag link also Idler arm n new sleeves having a toe adjustment issue maybe need the 75 duster spindles n arms as well ??
