71DodgeDemon340
Hey everyone, i guess im on a aluminum kick now lol. When i first built my demon we used factory pulleys as i was on a budget, i used factory water pump, crank and alternator pulleys to free up some cash for other parts that were more beneficial to the extra green backs. I had to install i believe a march performance power steering pulley on my federal pump because i could not get the pulley to budge off of the old one, so i already have my power steering pulley in aluminum but was thinking of swapping my crank, water pump and alternator pulley to the aluminum so they will all match. Any pros and cons of the march vs cvf? I still need to measure my pulleys to make sure but i believe my crank is 5-1/4, the water pump pulley is 6-1/2 and the alternator pulley is 2-3/4. I know the cvf will probably be cheaper but i have the march power steering pulley and would like them to match. Also i know the crank and water pump pulleys are just a matter of unbolting and bolting but the alternator is a factory replacement one with the pulley that came with it, whats the easiest way to swap the alternator pulley? Thank you for any guidance
