Cope
Fusing with fire
Huh, that should be a nice CFM.
Vacuum secondarys right?
That should be a hell of a street stomping set up.
I can tell it's got very good throttle response and when it gets tuned in I'm going to probably be pretty happy with it. It's just the learning curve again LOL but again like you were saying it's her toys to play with and when it gets boring then gets tossed aside...Huh, that should be a nice CFM.
Yes but I haven't had to adjust those yet. It seems like a pretty good transition... They have Holley secondary Jets and their own standalone metering rods and primary Jets. I just found out a trial-and-error that they do have the same step up Springs as the Edelbrock and I believe they have the same acceleratorpump as well and I think some other part that I can't remember. Post 1489 on the last page kind of has a rundown on the step up Springs of both.. the difference you can see is between the 6 and the seven spring.. one has one and one has the other but all are the same.. there's one major difference Edelbrock Springs are about $9 a set and the Demon Springs I got $27 a set remember , ×2..sorry, I've been out of touch with the latest and greatest on this thread. Do those Demons have adjustable air flaps like a TQ ?
From my TQ days..... those back flaps are the most important adjustment in getting the carb to respond at a instant mash of the gas pedal at a low rpm. They work very successfully if one takes the time to get them set right. You have 2, and they must work in unification.Yes but I haven't had to adjust those yet. It seems like a pretty good transition... They have Holley secondary Jets and their own standalone metering rods and primary Jets. I just found out a trial-and-error that they do have the same step up Springs as the Edelbrock and I believe they have the same acceleratorpump as well and I think some other part that I can't remember. Post 1489 on the last page kind of has a rundown on the step up Springs of both.. the difference you can see is between the 6 and the seven spring.. one has one and one has the other but all are the same.. there's one major difference Edelbrock Springs are about $9 a set and the Demon Springs I got $27 a set remember , ×2..
Today was starting from the ground up and getting the primary idle circuit correct. Yesterday it was running so rich when I first tried it out, and it was choking out when I hit the secondaries. Today all I did was take those heavy number seven Springs out and put the yellow Springs that I had in my old Edelbrock in there and it was instantly and major difference.. I counted the turns on the idle mixture screws and the rear carburetor had one and a half turns out and the front carb two turns out.. I turned the fronts in a half turn to match the back and picked up a little bit of idle and got a little leaner.... Just changing the springs the wideband O2 up about two and a half.. yesterday it was running around 9 barely 10 and today I was seeing hi 11 12 and 13's.. another thing that O2 sensor was going a little crazy...From my TQ days..... those back flaps are the most important adjustment in getting the carb to respond at a instant mash of the gas pedal at a low rpm. They work very successfully if one takes the time to get them set right. You have 2, and they must work in unification.
I have the rear one locked out as in Twisted all the way forward and it's wide open and the front one I can visually see the doors open and I twisted that one a little bit further out as well so we'll see what's going on there...Are the carbs sticking on the high speed idle screw?
Do you have the hot wire to the choke?
I think that did it there was something hanging up on the choke I believe. I think I have it shorted out now.Are the carbs sticking on the high speed idle screw?
yeah that's the way I went first and then I put a quarter-turn closed and it seemed to help more.. but by far not enough.. I might have to continue that direction but I really need to get a read on these plugs and figure out if I need to throw these leiner jets in? Or I need to change my step up Springs?...I would think opening the air door to soon would create more of a bog. aka AFB
