67sfFish
New Member
Does anyone know the correct master cylinder for a factory front disc brake car on a 67 barracuda? Thanks
I'm not sure what the insides of that look like but on the outside that is a drum/drumView attachment 1716147414
RA may not list them under "'67 Barracuda", but there's a number of them listed under '67 Dart. Same unit.
1967 DODGE DART 4.5L 273cid V8 Master Cylinder | RockAuto
not from a typical parts store or anyone getting their parts from companies like Cardone
I have also not found anyone that rebuilds . Napa listed a rebuild kit for these but no longer available. Maybe some of the custom rebuilders could do it. If you have the original 1" bore Bendix casting with the retainer screw for an A body, hang onto it. I was lucky enough to find one some time back but have not seen any since. I remember a RAM Man video where he said they were unobtainable.From my research, no one is rebuilding the 1" disk /drum. You can get the 1 1/32" or the 15/16 but not 1". In disc / drum.
And it will not have the holes for the stock dust cover piston retainer as it uses a snap ring to keep the piston in place.
I have been looking at nos rebuild kits but 40 year old rubber is worry some to me.
I've been looking at drum drum kits to see if the seals are the same but have not removed my OEM master yet.
