Just out of curiosity, I am in the process of converting my rears to disk and I want to also swap from my power master to a manual master and all my research says to go with the 15/16 bore as well. Do you mind updating when you get it all done so that I can get an additional opinion?
Thanks in advance
So what is the benefit of getting rid of the power setup and moving to manual?manual 15/16” is 100% the way to go.
I would say weight savings and the fact that you don't have the power brake booster as a limitation on camshaft size. Power brakes require a pretty strong vacuum signal, which somewhat limits the size of the camshaft. Lastly, in a car as light as an A body, power brakes are really not a necessity.So what is the benefit of getting rid of the power setup and moving to manual?
In my case it's just personal preference. My power brakes are "squishy" (although really strong) and I am just not a fan of how they feel. I want a more positive feedback through the pedal. Nothing is "wrong" with my booster or power brakes in general.So what is the benefit of getting rid of the power setup and moving to manual?
