72DMag
Does anyone have any recommendations for a mechanical fuel pump to use on a 318 for drag racing? Engine is a standard bore, stock stroke, 10:1 318 with 302 heads and a 650 demon carb. Cam is comp cams 268 grind flat hyd tappet. Car is going to have 4.56 gears.
Would like to have a fuel pump that does not require a fuel regulator like the discontinued Carter M6902 fuel pump.
