New adjustable dizzy in. Still misses
Going to put a new module in right at the dizzy and see what happens
Weird... is there any possibility that the distributor sensor wires were flipped in the process? Any module (HEI or otherwise) triggers off of a + going edge from the reluctor, which is the leading edge of the reluctor pulse if all is set up right. If the wires get flipped, then the module will trigger off of the trailing edge, which will make the actual timing vary all over the map. That would explain the big change in timing.Problem Solved!
I moved the HEI module to be right at the coil and dizzy. Checked timing and it was 50* at idle, yet it was 18* when module was at the old location.
I am pretty anal about that kinda thing, but I have to admit, that is such a no-brainer thing, I didn't check that.Weird... is there any possibility that the distributor sensor wires were flipped in the process? Any module (HEI or otherwise) triggers off of a + going edge from the reluctor, which is the leading edge of the reluctor pulse if all is set up right. If the wires get flipped, then the module will trigger off of the trailing edge, which will make the actual timing vary all over the map. That would explain the big change in timing.
Regardless, that was a vexing problem; you get a lot of credit for the persistence to figure this out.
