mini tub pictures
604 Racing
604 RACING
Vancouver, Canada
post pics of your minni tubbed ABODY, aswell as tire/rims size/bacspacing,
i just finished the minni tub and narrowing of my rear, ill post pics as soon as my rims come in.
Mini tubbed, quarter panels trimmed back about 1/4 inch, Strange 60 narrowed 4 inches on each side, 325/50/15s on 15x10 wheels with 3 1/2 inch bs Fits like a glove!! I have about 1/2 to 3/4 inch clearance in the front and outside with absolutely NO RUBBING!!! I measured about 100 times before ordering my wheels.
I have a 17x11 with 4.25" backspace. 315/35/17 tire. Overall tire height: 25.6" Strange S60 built to 49 5/8". 373 gears, detroit locker.
The specs would be nice.
I like the idea of this thread. Ya you can search "mini-tub" but you'll be wandering all over... this would put things in one nice thread that will make planning easier.
BTW, when diff width is given I presume its to outsides of the axle hubs?
Also, I wonder if the thread title should be changed to "mini tubbing" rather than "minni" so its not missed by the searchers.
Mini tubbed, Strange 60 narrowed 4 inches on each side, 325/50/15s on 15x10 wheels with 3 1/2 inch bs Fits like a glove!! I have about 1/2 to 3/4 inch clearance in the front and outside with absolutely NO RUBBING!!! I measured about 100 times before ordering my wheels.
anymore pictures? im looking at the same rims for my 71
Stock A body rear,18x10s w/7.2" back space 335/30/18 Toyos,springs moved and mini tubbed.
Im running 17x10.5 w/4.5" BS bullets on an A body stock length axle with 315s. the disk brakes and double axle seals pushed them out a little. These are the only pics I have, sorry
Andrew
Mini tubbed with narrowed 8 3/4, 10" wheels with 4.5" backspacing. Tires are 28 x 13.50 x 15 M/T DOT slicks
67 dart mini tubbed, springs relocated, narrowed c-body 8 3/4 to stock A-body size, disk brakes, 15x10 steelies (i believe it was 7 inch backspace) with 295-50-15 good year gtII
Dart still in body work
guys...whats wrong with leavin em "stock"?
BTW..you don't have to answer that.....
Photos of the process on my '70 Dart.
http://www.rhphoto.com/mini_tub.html
I am running 29.5" x 10.5-15 wrinkle walls. I ordered my Caltrac monoleafs with the spring mount moved 1" back for additional tire clearance in front of the tire.
Ah mini tubbed, sorry I read it wrong
Andrew
Are you sure you only have 4.5" bs? Didnt know you could even get Bullets with that little of backspace???
You guys have some sweet cars. I have a 75 duster minitubbed, w/ Dana 60 Fremont a 69 ford F250 narrowed and converted to semi float axles ( mosier 35 spline) Detroit locker, and 31/10.50 15 Hoosier slick. Can't post pic from my phone but here is a link. Car is still in fabrication, but once fab is done I'll work on making it look good.
http://www.dodgetalk.com/forums/showthread.php?t=317199
Just to let you know. It says you have to be a member of that site to see the pics. Sounds cool though and I would like to see it.
