Ironmike
Hey Tim! I see ya there....how the he'll you doing bud?Mike, I’m just glad your stickin with it.
True grit and determination!
He’s of luck and wishes for you!
The heads are New, bare bones Edelbrocks. He's kinda doing as a personal project rather than a shop thing because they do not HAND port heads anymore. Good guy.
I have heard nothing about the Bloomers. Might be something over on Moparts but I doubt it. Bret Miller said somewhere over here that he would update us. Rod Bloomer told me they were just dropping the whole program. So.......who knows....
Thanks for the support!
Good, the port design was garbage...sad Brett put his name to it...talk about jumping the gun.
I thought Brett developed that port?
Fixed it ^^^ and doing fine. Wallowing around in winter time pain of no wrenching fun.Hey ROB! I see ya there....how the he'll you doing bud?
I never had the Bloomers flowed, just the Hughes Eddy`s. After they made 40 HP less, I just didn't see a reason to flow them. If I remember, Rod Bloomer jumped in pretty quick to give me a refund. He seemed like a really good dude. I felt pretty bad about that whole deal but for 2200 bucks.......They had to go.He sure did, but I wouldn't have released it with my name all over it until it was proven at the flywheel.
It looked bad and performed the same.
If the velocity is poor... you are fkd.
I've rolled around in my mind "bandaid cams" that might work better , old .557 296 110 slower to keep seat velocity in charge longer.
Then I say ...what did those blooper heads flow again and what lift? Were they slow movers? Or just **** mixers with "fuel separation" wet flow would look interesting... I'll look again after post and edit, but if that' the case...cam won't much
Same here. Lots of quality farting around my garage doing nothing important. Spring seems farther away than ever. I think it's age.....Fixed it ^^^ and doing fine. Wallowing around in winter time pain of no wrenching fun.
COME ON SPRING!!!!
Thank god i did not go with BLoomer heads ... was so close to buying them.....
You would think that Brett Miller would of worked his majic to make them work ????
If i was staying with small block i would consider the new Smallblock Trickflows ???
Yeah, but I'm talking about the Bloomers.I sure wish I had a set of them!
@pittsburghracer: these trickflows should be a stock replacement.....i´m also interested in these. I think you are talking about the EDE Victors?
Michael
I think Jim said he is retiring or is retired. he is probably planning his spring bear hunt.IQ52...call Rod... you maybe able to get a set cheap... may even be able to save the heads after you work you porting majic .
