Negative. Big and small Chevys use the same mounts.
I agree, it's super cool. Keep the pics comin.
What about dimensions, are they the same, too. Block length, etc?
The distance from the mount to the bell housing, trans mounts, etc?
Yes. Generally speaking the bigun will bolt right where the smallun will. Same bellhousing pattern, same distance, same mounts. Although the big block heads are very wide, the difference went inside, towards the center of the intake. The intake on the small block is actually wider. This makes the outside dimensions on the two engines very close together. In fact, the bare blocks are very close to being the same width.
I have built a slew of Chevy hot rods in the past. Actually thinkin about another 68-72 Nova.
I've built some Chevies, too, but never made a mouse/rat swap, or vise-versa. That's real interesting, though that they had the foresight to simplify things like that.
I liked the first two Nova body styles. That sounds like a fun project.
Thanks Rusty.
That looks like a good option with good reviews.
Anyone got thoughts on running large AN fittings and line right out of the intake to the radiator VS a thermostat and that gauge hose?
I would be interested in folks thoughts on running g a mag VS MSD dizzy and 6AL.?
Thanks again for all the time and advice.
Here's a few more picks for ya before turkey day.
Here's a shot of the 32 A. She should be quite fast as well.
Pay no attention to the car on the lift, it's not one of ours.
With the mechanical injection I'd run the magneto. Vertex or Joe Hunt.
MSD is just a multi spark electronic ignition that you can't even put good
copper core cables on without it going to hell over the rfs. Then there's the graphite spiral bull that wont last or even come close to copper as a conductor. Their only used because they don't generate the rfs and they can sell a lot more of them cause they dont last.
MSD has its place in racing with electronics. Snooozzzz.
Doesn't belong in any vintage or nostalgia racing.
I just want to get back to basics with something. Just real tired of special and expensive parts. If I am to stay in this hobby, it is gonna have to be done as cheaply as possible. Even the RobKat is beginning to stretch the limits of the budget and it is very close to being on the road.
Like it or not, Gm sure knew how to engineer a Auto. You can put any engine into any car GM made very easy, Not this Mopar engineering. This engine will only fit in this body.....Yes. Generally speaking the bigun will bolt right where the smallun will. Same bellhousing pattern, same distance, same mounts. Although the big block heads are very wide, the difference went inside, towards the center of the intake. The intake on the small block is actually wider. This makes the outside dimensions on the two engines very close together. In fact, the bare blocks are very close to being the same width.
Surely the frame is boxed....???
Yup. I've always said that people who knock GM and Chevys, have never had one. They have Mopar beat in a lot of ways, not even counting the parts availability end of things.
I still love Mopar best, but not where my finances are concerned.
