pauly v.100
They could be brighter I suppose!
I've noticed new cars with turn signals that I could not see because of the headlights.
How long will it I have to wait for LED lights to replace my 6024s that don't cost 300 dollars a pair?
Tuck-lites are getting cheaper, and have Dan'a seal of approval. I had them on my Jeep and they were good when properly aimed.
Not quite -- this what you're seeing is not the headlamp (as such) turning off, it's the daytime running light (which may be the headlamp operated at a lower-than-normal voltage) turning off on the side the turn signal is operating on. That's required with certain kinds of DRLs and certain separation distances between the DRL and the turn signal. It's for daytime only -- it would be an extremely bad idea (not to mention illegal) to turn off the headlamps one at a time while signalling for a turn at night.
If you see this happening at night, it's because some dillweed is driving around after dark with daytime running lights instead of full nighttime lights on.
Have to say, though, that if the DRL turns off so you can see the turn signal, and the headlight doesn't, then there ain't no way someone is seeing the turn signal with the headlight on. The headlight is brighter than the DRL, so it would have to mask the turn signal like you are saying it isn't supposed to.
I see more and more of these awful, unfocused, glaring bluish headlights on 10 year old junkers. How do they pass DOT or do most of the Ebay junk lights not comply?
And to think they got rid of perfectly good lighting systems that Honda spent millions designing to work right, to "upgrade" to cool blue lights, dude!
Those look GREAT!!
I've been looking at the same model except in black for my dart.
JW Speaker Evolution 2 Headlight Kit
Are you happy with how they function?
I wonder if Pauly had to modify the headlight buckets. The trucklites are a bit deeper than the stock heads.
Yeah, they're definitely way too dim and way too small even by the standards of the 1960s. Minimum allowable lit area of the front turn signal is 22 square cm (3.4 square inches).
Here's the thing: all vehicle exterior lighting functions, even the ones that aren't mandatory (like daytime running lights and side turn signal repeaters in the USA, or central brake lights on cars made before 1986, etc) are highly specified as to their design, construction, numerous aspects of performance, durability, etc. It's far, far more detailed than just "Well, it's a red light facing rearward that comes on when I step on the brake, so it's a brake light" or "Well, it's amber and it blinks, so it's a turn signal" or "Well, the eBay ad said tail light, so that's what it is", etc. We do not get to just declare any ol' light into whatever function we want -- doing so is unsafe, even if we don't have to pass an inspection. This stuff matters if we want to keep the car (i.e., not get hit in traffic).
Double-whammy in this case: front turn signals mounted within 4" of the headlamp (or the low beam, on a 4-lamp system) have a minimum intensity requirement 2.5× the requirement for turn signals located farther away from the headlamps. That's so turn signals mounted close to the headlamps can still be seen at night with the headlamps on.
(also not "Well, if it's good enough on a motorcycle, then it's fine on a car" -- motorcycle requirements are way smaller/dimmer than car requirements).
There's probably an easy and inexpensive way to have good front turn signals with an appearance you can live with. How much height do you have between top of bumper and lower edge of that ridge where your present turn signals are located?
