1970Duster
- Joined
- May 30, 2010
- Messages
- 6,644
- Reaction score
- 219
They are new aftermarket housings. You can find them pretty much anywhere.
Got a link?
watching this(in the dark)
Just a word of caution... I put the aftermarket 7" housings in my 67 about 5 years ago.
Yes the wire connector for these fancy little bulbs is different and yes you will need to upgrade the wiring with relays or you will fry the stock headlight switch. that switch and the wiring going to the original sealed beams is not adequate for the amount of current these little bulbs will draw.
Now for a unforeseen issue... The original sealed beam is not as deep as the aftermarket assemblies so it fits in the headlight house with no problem.
The aftermarket fixtures you purchase may be so deep that they crush the wiring behind the bulb against the headlight house.
While this scenario hasn't happened on my car yet, I do predict that the wire insulation will chaff against the sheet metal and create a short circuit eventually.
In a more perfect world we could simply cut away a portion of the headlight house sheet metal and gain the ability to replace a bulb from under the hood like some modern vehicles. Not gonna happen with these Chryslers. Cutting an opening in this headlight house will only expose the fixture to the wheel well and we don't want to do that.
Where is Slant Six Dan? Probably got tired of having to recite the same things over and over....I can say I was looking at putting aftermarket headlights in our Explorer. After talking to Dan he changed my mind. I went with a set of Ford lenses, a good pair of bulbs and relays and am more than happy with them.
That's what I was thinking. I saw him post in a thread while this one was at full heat. I almost wanted to PM him to get him in here but I figured, as you said, he probably didn't wanna recite this for the millionth time.Where is Slant Six Dan? Probably got tired of having to recite the same things over and over....I can say I was looking at putting aftermarket headlights in our Explorer. After talking to Dan he changed my mind. I went with a set of Ford lenses, a good pair of bulbs and relays and am more than happy with them.
Yeah, I don't post much any more; my stuff's still accessible via the search function.
fez440 green demon is just what I had in mind with also blue halos for accent lighting at cruisins to match my gauges and interior lighting! I was also planing on wiring in realays to take the amperage load off the switch and bulkhead connector.
I was looking at these on ebay http://item.mobileweb.ebay.com/viewitem?itemId=330724019189#
I guess the Halo's would be nice yet, I have taken a different route where my headlights are Halogen and the amber parking lights are also the directionals which are enclosed inside the headlight itself. In the early evening the headlights turn amber in the parking light position. The Barracuda grill houses driving lights which are blue but turn to white light when on. I'm not really ol'school or new school, yet I am low key when it comes to being stopped by authorities. Here's a photo and you can see the amber bulb in the passenger side headlight..
http://s444.photobucket.com/user/joeymadden/media/Cars/66016.jpg.html
got a link to at 1400 a pair lights?
Without a better picture, I'm betting that those are late-model Harley-Davidson projector headlights, introduced in 2006 for touring models in the Part's and Accessories catalog, later to be factory installed on CVO bikes beginning in, I believe, 2008. I think #67700033 would be the same.
Lets see who knows what these are?
Have the smaller version of this
https://www.streetrodhq.com/shop/de...D_HEADLIGHT_Xe7R_7_ROUND_BIFUNCTION_TWIN_PACK
on my bike, can't say enough good things about it. Have heard a ton of less than favorable things in regards to halo lamps....
says discontinued...
Truth of the matter is the smaller version on this lamp throws a ton of light. Optics seemed great to me. With how it was aimed I never got flashed by traffic unless it was on high beam.
Might have noticed that I am speaking in past tense here. Because on my way home from Spokane County Raceway last night the headlight broke for the third time. Last two were under a warranty. They claim that the headlight is very durable.....they lied.
The point of my earlier post is that if you buy good quality lenses, put a good bulb in said lens and see to it that it is indeed getting as much voltage as it can the results will be very satisfactory.
To each there own.....
A bunch of different lamps are pictured on the vendor's site you linked. At the top they show the (out of production) ValeoSylvania XE7. That was a very good performer, and it was mechanically pretty robust, built around a Valeo BiXenon projector used in a variety of high-end vehicles as original equipment. But they made some strange packaging choices so major surgery was often required (hack the headlight buckets) to make it fit. There was also an XE7R and smaller XE5R in this family. Those used reflector optics instead of projector. Beam performance was OK, not as good as the projectors, and the high/low hood wasn't as robust as the high/low cutoff shield in the projector version. These "R" versions, also no longer made, aren't shown on the linked site.
Next, under the weird heading "Xenon-HID Sealed Beam" we see the Sylvania Xenarc X1010 auxiliary low beam set. Out of production for years. Never very good, but can be made somewhat less bad by replacing the nonstandard bulb (bluer but dimmer) with a standard bulb.
Below that, the "Xenon-HID XP6024 Projector fits H6024 and X6024", which is a headlite-shaped toy made in Taiwan by GiantLight (see third item here). If you get ones that work out of the box, they give passable performance until they fall apart. They also make the car look like it needs a bra. The same Giantlight company makes a range of toys shaped like LED headlights, too.
Below that, the "Xenon-HID X6024 Sealed Beam headlight kit", which was a ridiculously lousy product made in China by a guy who chose the English name "Clutch", puttering in his basement workshop. I'm not making this up. The guy had absolutely no knowledge, equipment, or business making headlamps, but in 2000 a Mexican fast-buck artist in Canada managed to con Sylvania into thinking he could supply them with a complete turnkey range of HID headlamps in standard sealed beam sizes. Sylvania wanted this product to get more people experienced with HID headlamps on the aftermarket side so they would buy more HID headlamps on the OE side when they bought new cars. It backfired spectacularly; the packaging was sexy but the product was garbage. Its performance was much poorer than an aged sealed beam, the lamps didn't fit properly, lenses turned yellow and fell off, etc. The whole range (large and small round, large and small rectangular, plus the X1010 aux low beams) was quietly discontinued around 2005 and remaining stock made its way to other fast-buck artists including brightheadlights-hid and suvlights.com, where it fit right in with those vendors' other Chinese garbage they were selling.
Yup, usually so. Even a vehicle with lousy headlamps (for which no better ones are available) will let you see better if the headlamps are in perfect condition, aimed correctly, and equipped with good bulbs fed by good wiring.
Usually, but in the case of a vehicle's exterior lights we're talking about life safety equipment. Modifications that result in objectively unsafe lighting affect everyone on the road, not just the vehicle owner/modifier. And objective measurement is the only way to answer the question of safe/unsafe; peering at the lights or going for a drive and saying "Yep, looks great to me!" doesn't cut it.
BINGO!
:burnout:
