Can’t find the MOOG offset bushings
Upper control arm for my 70
Dart factory Kelsey Hayes discs
Is it required to have eccentric bushings on both the forward and rear uca bush holes or do you just require 1 in the forward uca bush hole and a normal bushing in the rear uca bush hole
Alright, makes sense I forgot, "run as much positive camber as you can get". And if I were to also use a higher degree + or - 2 1/4 degree alignment bolt We'd be able to squeeze a little more positive camber?I mean, it's not required to use them at all. But if you want to get enough positive caster for a decent alignment with a set of radial tires you'll need them in both locations.
Even using 2 eccentric bushings per side it's unlikely you'll be able to get more than +3.5° to +4° caster. Which is the most the SKOSH chart shows, although honestly I think the SKOSH chart is really conservative on caster. Personally I think you can add +1.5° to its caster recommendations across the board even for manual steering. I'd never run less than +3° even for a cruiser with radials.
PS why "radial tires". I realize next to no one is running bias ply tires anymore. Just curious.
Thanks
That's what I did. May remove and replace the rears, as I already have em. Just did LCA Bushns, and was Blessed to find a set of the Moog Strut Bushings. So before taking it to the worst of the best Local Yocal alignment places.....Is it required to have eccentric bushings on both the forward and rear uca bush holes or do you just require 1 in the forward uca bush hole and a normal bushing in the rear uca bush hole
