This!!!If you worry about what others think, just sell the car now.
Make it safe and enjoy!!!!
given the state of affairs, i'd be replacing the hard line there. so i'd pop the clip and just cut the line and thread it thru.NOTE: any tips and or advise in loosening the rubber brake hose 5/8”??? They’ve been soaking for a week in Pb and still won’t let go… thanks everyone and happy wrenching!
Sway bar is in the works at the moment and on pause while other pieces are being gathered. Now into the front end suspension, rubber replacement and overall refresh.Think I suggested a new bar earlier....way easier and probably not much difference in cost... You have soaked that fitting and heated it w/a torch?????
Yes, thats how I did it. Some dont like splices. but I NEVER had an issue with one and a brake shop I talked with said he had installed hundreds over the years successfully. You can probably get a 12" splice/line kit at a local parts store. These are 2 I just see on Amazon- you would just cut off one end and use a connector w/ferrule. https://www.amazon.com/MuRealy-Brake-Line-Repair-Kit/dp/B0CCS1YQ3R/?tag=fabo03-20Oh ok I think I get it… you cut above or before the rusted nut/ coupler and spliced in from there? Am I understanding that correctly? Just eliminating the rusted damaged sections? The remaining brake hardlines should be ok?
if the outside of that looks like that, what's the inside look like?Wow thanks for that! That might just save me the trouble of trying to salvage the rusted and corroded parts altogether. Thank you!
Very good point and yes you’re right… would you happen to know is there such a kit or setup that includes lines already pre-bent for remove and replace? Junction blocks as well I would imagine. Thanks!if the outside of that looks like that, what's the inside look like?
out of an abundance of caution and in the name of safety i'd be replacing all the brake lines on that thing.
Thank you! I’ll check them out!Inline Tube is my go to for pre-bent brake and fuel lines.
PS: If you need to bend it some, the newer GREEN colored tubing is easier to bend- as it it does not KINK as easy. Yes, it can be tricky, but a cheap bender helps if you really need one.Wow thanks for that! That might just save me the trouble of trying to salvage the rusted and corroded parts altogether. Thank you!
I appreciate all the help I can get I did not know about the GREEN tubing and will certainly look for it. Thanks!PS: If you need to bend it some, the newer GREEN colored tubing is easier to bend- as it it does not KINK as easy. Yes, it can be tricky, but a cheap bender helps if you really need one.
