TrailerParkGinger
I like your style haha.Since I like to rev the crap out of my engines. I would do the oiling system modifications and probably rev that thing to 7500 on more than one occasion. LOL
the mopar 380hp crate engine cam is 230/236 .050 .501/.513 lift at 108 LSA.
You are insane!That magazine engine looks pretty good to me;
Except maybe the power-peak at 6000rpm. That kindof demands a 6800/7000rpm 1-2 shift,
Hate that cam. Then again maybe the engine wrapped around it is wrong too. J.Rob
Well the man has spoken! I guess I'm following the blueprint he laid out. Thanks for your input Brian! This forum is awesome!Just to be clear...I chose the cam! It was my choice, and I wanted to use a cam that I believe would make great power everywhere in the operating range I wanted (2500-6500rpm), and also keep cranking psi in check. A custom cam would have made better power in certain spots, but difficult to make more power everywhere from bottom to top.
If you stray away from the combo we layed out, be careful...as mentioned with an iron head compression is pushed with 10.4:1...that's why we put that cam in almost straight up!
Also, cams are being talked about very cavalier....not good! You cannot just get close with cam timing, and have the same results. Not even close!!
If you plan on changing cams, you will most likely either need to drop compression, or play with the installed specs of the cam. This can change the characteristics of that cam very noticeably.
Edelbrock heads OOTB, will be down on power over the iron heads we used by about 20HP.
Brian
If you're NOT going to stretch it out to plump up your powerband, then there is no point in running such a "big cam", becauseI would probably never take it past 6 grand anyway, unless the occasional strip time. I'm looking for a really fun street car, with occasional strip time. I'll probably do a few oiling mods anyway just to make it live as long as it can.
Well I don't have superstock suspension, thats for sure. I just have the heavy duty ESPOs 2" over stock with the 318 torsion bars. I plan to stiffen the chassis with connectors and torque boxes. I'll have to see what I want before I order the cam and such. It's a lot to take in from all these knowledgeable sources on this board. If it'd be safe I'd rev it to 6500-7k I would, nothing sounds better than a high strung small block.What oiling mods would need to be done? Extensive ?If you're NOT going to stretch it out to plump up your powerband, then there is no point in running such a "big cam", because
A)you are sacrificing average power at the track, and
B) there is a good chance that the next smaller cam will have the same average power when stretched out properly to a lower peak rpm, and the low-rpm power of the smaller cam may very likely be stronger, making the use of a 4000TC not necessary, and
C) like you said; your 4.10s with the 29s are equivalent to 3.75s with 26.5s. So a little more bottom end may be appreciated for a guy who wants to be gentle on his engine. And the truth is how often are you gonna stretch it out to 7000?, which in your combo is pretty much right on 57mph at the top of first. Yeah, on paper, it's a great combo. But those tires with street suspension,are gonna spin all the way thru first gear,with that engine....... and also with one that has two sizes smaller of a cam, with properly matched compression. That begs the question " how much quicker will a 455hp engine be than a 420hp engine?, from zero to 60,in street trim? And what do you have to give up to get that fraction of a second.
D) and then, 3650/455=8.0wp and that is good for about 116 mph. Which is good for about 11.5-ET with a SuperStock suspension and the right gears. But with your street set-up maybe low 12s, say 12.1, or slower if you shift at 6000.
But; 3650/420=8.69pw, which translates to about 113mphand a possible ET of 11.7 with SS suspension, and possibly 12.3 in street trim if you find the right shift-rpms. So again, what are you giving up for .2 second ET?
IDK man, I'm at 3650/400=.9125 or about 113mph. Which in street trim is a theoretical ET of 12.4. That's quick enough and fast enough for this cowboy.And it makes an awesome streeter.
Jus saying
Brian,Just to be clear...I chose the cam! It was my choice, and I wanted to use a cam that I believe would make great power everywhere in the operating range I wanted (2500-6500rpm), and also keep cranking psi in check. A custom cam would have made better power in certain spots, but difficult to make more power everywhere from bottom to top.
Brian
Haha! I kinda wanna rev to 7grand now lol. I think I'll just keep the thumpr and rev the snot out of it if its that entertaining! My 255s won't stand a chance. If its safe to rev to 7k I'm a lot more tempted to do so. Sorry I don't have an Abody, yet! I want a dart something fierce. My dad drove a 73 slant Dart for years and it was reliable as hell.You got that right! 7200thru the Dynomaxers, and dual 3" all-the-way pipes sounds awesome , and when my son drives it I tell him not to hold back, it sounds even better from the roadside.
Properly set-up, 7000 is easy-peasy for a 360. Mine has been doing it since year 2000. and has over 100,000 miles on it. Almost not a day went by that it didn't hit 7000 at least a few times. I'm geared for 7000=51 mph,and again at 66mph. But.......the little cam in mine peaks at about 5300, so it wouldn't need to go 7000. 6000 would be plenty, in terms of putting down max average horsepower. But .. firstly, it doesn't matter, the tires are spinning, and secondly, the screaming 367 is such a pleasure to listen to all 5 or so seconds of it at a time,lol.
A person might wonder why I have never done something about the traction issue. Well, I find so much pleasure in sliding the little Barracuda everywhere, that I won't give that up. And I don't streetrace it, so it doesn't have to be quick. It only has to make me grin. I built it for me,and for my son, who was 16 in year 2000. We choose our spots. Nobody eggs us into doing really stupid stuff downtown. And lest you think I'm a dangerous driver, in all those years and miles, I accumulated just two tickets. And in both cases the cop said something like; "I can't let you get away with that, since you did it right in front of me, but you sure do it good". One incident was on private property. The other in a deserted area. Up here the monetary amount of the ticket comes in a range, that the cop has discretion to choose, and in both cases I got off at the cheapest level. I love sliding,and I'll have to get a lot older to stop that silliness,lol.
Thank you! Its my baby. My old truck is a workhorse but I think it needs new rod and main bearings.Cool car TP Ginger.
There is no reason to shift point a SB mopar or any engine to insane RPM's if it stops making power 1000+ rpm lower the shift point. The one reason to spin it higher is if you are running a gear that requires it to spin out the back of the 1/4 mile in high gear.
Some cars/engines like being shifted slighlty above the peak HP observed on a dyno. In the 200-400 rpm range. I've never seen a set up that liked 500 or more rpm.
I used to drive a lot of cars many years ago at test and tunes and street racing. I'd ask most of the owners/drivers where they shifted. Almost every time I would shift the car at a lower RPM and the car would pick up et. DOH!!!! One car I got told it was shifted at 5900. Knowing the set up, shifted at 5400, car picked up .15 ET at the stripe. Go figure. It was a BB mopar More RPM without benefit is just unnecessary wear and tear on the mill.
Me likey 7000, it sounds so crazy to hear a Mopar in that territory. I go there just to be there. I bust the tires loose and keep it there for 5,6,7,or 8 seconds,jamming thru the gears............ Then stop, turn around, and do it again .
Brian likes to apply them to builds , and advances / retards initial cam timing ,as needed .It would see that engine recipe was purpose built for the Thumpr camshaft and thus is most efficient with it. I don't think I would feck it up.
