abodyjoe
proper way to run 70-up non a/c belts..
70 and up a/c cars had a double groove water pump pulley and double groove alt pulley. They had two belts spinning the compressor that ran off the crank-alt-wp
You are close, but I think the non-a/c cars had a single groove alt pulley - it aligns a little better...
70-up a/c cars had a single groove wp pulley that went crank,wp,ps. the rear two grooves on the crank pulley went crank, a/c compressor, alt.
Ok, I see. The alt - a/c belt was separate from the water pump...
But I still say the non a/c lines up best with the single groove alt...
as long as you are using the proper non a/c bracket and spacers the rear groove on a double pulley alt is in the same location as a single groove alt.
