mopowers
I took a break from the headache headliner and decided to install the trunk seal.
With that roll bar, you sure had enough obstacles to work around. Good thing you're not a fat guy!This weekend I was able to finish up the headliner. It was my first one but I'm pretty proud. A total pain in the ***, but more tedious than "difficult." Not bad for a bonehead.
You're right about that. The cage certainly didn't make things easy. I just wish I was as flexible as I used to be.With that roll bar, you sure had enough obstacles to work around. Good thing you're not a fat guy!
Thanks! Slowly but surely... Now that the windshield is in, I just have to throw the interior parts in the car and the interior will be done. Then I've gotta run some wires and that's pretty much it.Nice progress, keep it up.
Thank you. I'm not sure if the later Darts are any different, but on the '66, if you have the perimeter of the headliner glued in place with contact cement, it's pretty easy to go around anywhere that's wrinkled, warm it up a tad, pop it off the cement, pull it a little tighter, and re-stick it. If that doesn't work, I've heard several hot/cold cycles may eliminate some of the wrinkles as well. At the end of the day, if there are some wrinkles, it's not the end of the world. Good luck!The headliner looks great. I just finished mine and it is an 8. Waiting for cold weather before using a hairdryer to heat and cool to hopefully draw out some areas I am not happy with.
Thank you. I'm looking forward to getting this finished with. Or close enough to drive or do some burnouts at least.This is the kind of car that stops me at a car show. All the details and clean work stands out. You can be proud of how it looks!
