This is a copy of the last time this was asked :
before you even think about installing it. you might want to put some sort of solvent in it and check it for leaks! I found my pin hole leak in one of the welds. When I called*Milodon*old man sighed and said oh boy Again?! California laws don't allow them to use solvents to test for leaks. they have to use water and don't catch them all!
you're cut your K frame, bang out the back of it and grind on your high volume oil pump to make it fit over it, you'll bang out the side of it to make the oil pickup set. good Lord have fun I'll never buy one again, all the while hoping it doesn't leak like mine did brand new.
