340 Dart
I don't know ****.
Glad this got bumped again.
I missed it somehow and will be doing the swap soon.
:read2:
:read2:
Not true. The passenger side is indeed the different unit. Those images in Neil's original thread are mine (unfortunately so are the sketches and bad penmanship).
The knucklehead is the one who authored the Mopar Chassis manual section on modifying the bracket for doing the swap. It it plain to me that the engineer sent a lacky out to the garage floor with the instruction that he needed to get the dimensions off the "right side mount" and the goofball looked in the engine compartment, looked at his right hand, then took dimensions off the drivers' side mount. ](*,)
The difference between the 273 and 360 block is the configuration of the passenger side ears: the 360 only having one tab on the rear and two in the front, but the original 273 bracket is intended to use two holes in back and one in front. the rubber mounts are the same side to side (regardless of LA motor), but the brackets are indeed different on the passenger side for a 273 versus a 360.
Excellent photos JD. That last one is a 318 mount. The one in my photo is an original 1966 A Body 273 mount, and I had my 360 in the Vart with the original 273 mounts for many years - and will again if I ever get the sucker off the rotisserie.
Before you come on here and discredit a member, and tell him he is wrong, have some proof of what you speak.Here is mine.
First pic: 273/318 right (passenger side mount). Bolts up to the 360 no problem.
Second pic: 340 A-body left (drivers side mount). Bolts up to the 360 no problem.
Third pic: 273/318 left (drivers side mount). We have a problem.
So untill you can show me anything different,your information is incorrect.
It was not my intention to tell another member they were wrong, I was speaking Klingon: you were speaking Romulan. I was talking early A small block brackets, you are clearly showing 67+ era units. What I am trying to say is that we are both correct for our respective model year applications.:read2:
No harm no foul, and actually my proof was provided indirectly by Neil at the beginning of the thread and later in the post from the Early Valiant/Barracuda site. My slam was towards the Mopar Chassis manual author, as it was the errant descriptor. My apologies to anyone who took my explanation of the modification to the factory early A brackets for use with a 360 as an insult.
The thread got sprinkled with pre and post 67 A-body responses (which you pointed out in a subsequent post). My biggest error was not first asking the question about whether the responder was talking about a set of brackets from a 63-66 K-member versus those for a 67-72 K-member before posting.
Lesson learned.
This looks like a good time to ask this even though the topic supposed to be on early A motor mounts I guess.
I have a 67 cuda with a 273. The passenger side motor mount insulator does not fit correctly like it should and even though how hard I try I can't get it to line up properly. The left fits fine.
The picture of Johnny Darts 318 motor mount (the third one) does not look like my mounts at all.
Notice in the picture that the insulator holes are on the same side of both mounts. Aren't they supposed to be opposite?
Has someone installed the wrong mounts on my motor?
Are those the factory mounts?
Whats the history on them?
Through my studies the holes for the insulators should be forward.(Towards the front of the motor).To me it looks like your right mount is wrong.
Look at my pics again and notice the "holes going forward".
You might have a E-body 340 right mount.They sit to the back.(towards the firewall).
I think they are factory mounts. I don't believe they are for my motor and year. They are the ones that was on the car when I bought it.
E-body huh! I wouldn't be amazed because it sure dose not fit right. I didn't have the car long and it ripped the insulator in two on the passenger side.
Went out to the garage to find just the mount you need if you are interested.You will see the difference.
Charging the batteries in my camera,will have a pic up shortly.
John
Here is the mount you need.
Notice the difference.
If your interested in it let me know.
John
here are my 63-66 a-body v-8 mounts...
passenger side
drivers side.. you can barley see the triangle piece i had to weld on to use it on a 360
Just remember,holes go forward.
When I was looking for a A-body 340 left side mount,guys were trying to sell me e-body 340 mounts (Holes to the back on e-bodys).Hopefully this helps.
1 solid plus 2 rubber mounts usually equals a cracked something....but I agree that the 318 truck mount (or even the 360) is a great starting point for a custom mount.I have a 64 Dart GT with a 340 and a stock motor mount on the passenger side but on the DRIVERS SIDE I HAVE JUST THE METAL PART OF THE PICK UP TRUCK MOUNT !!! ONE SOLID MOUNT!!! NO I REPEAT NO RUBBER MOUNT ON THE DRIVER SIDE! BOLTS IN JUST LIKE IT GREW THERE FROM THE FACTORY. It would be very easy to recommend that if you were to put a HI-PO 318 or 273 into one of these cars the solid mount would seem to be very practical just use a 318 drivers side mount.
