Flatlander
OK, I had the motor starting and running several times. I adjusted the lifters to lessen the noise, it helped and I turned off the engine. 10 min. later I went to start it and did nothing but crank. I pulled a plug and it has spark. It is getting fuel, maybe too much, the carb. needs a kit. Would this have an effect? Any recommendations welcome. obtw it's a 273 2v.
