Just thinking out loud, can u bolt the 518 od tranny to a 5.7 Hemi, then u will have the best combination for fuel mileage. Is there a 4barrel intake for the Hemi? Kim
Its hard to recoup dollars spent on gaining mileage. Especially a summer only car.
Your better off just putting the dollars into the gas tank. It could take decades to recoup $5000.
It sounds like the discussion is evolving but I thought 273's post was an interesting point....and absolutely true. Doing the math on this one, especially with ~$3.00 hi-test gasoline, you'd have to drive A LOT of miles to pay for the mods with MPG improvements.
That said, it OP is talking road trip...and in this case range is a big consideration. So I suspect that fuel cost isn't the only concern.
As for the original question, I'd look at the cost of a Magnum with higher compression heads, custom cam and EFI compared to the 5.7 Hemi. It seems like this might tip the scales toward the Magnum.
Well I think I’m going to do the Magnum swap. I picked up free 2001 Ram that was wrecked. A tad over 200,000 miles, but the price was right. Looks like the trans was rebuilt,so that’s a step in the right direction. I am going to tear down the motor and rebuild it. Going to do EQ heads and figure out what cam will be my best option. I’ll probably do a tanks inc. mustang tank with the fuel pump in it and sink it in where the spare tire is supposed to go. Started working on the harness, so fingers crossed I can figure it out!
Regarding fuel tank, if you're going to cut up the back area for a tank you should consider making a space for a 15 gal aluminum fuel tank, $120, route the filler to it. You said you would like to use stock pump, cut a hole in the aluminum tank and place stock pump. A few guys have done this. You can even cut the collar from donor tank and bolt it to top of aluminum tank. Way more affordable thank tanks inc and plug and play with the fuel pump. I considered this route but for various reasons I could not.Mgoblue, on my Crewcab I used the entire harness including the pdc, gauges, fuel tank etc...The wiring is to bulky for me and I have a lot of wires bundled up and just tied out of the way. It is my daily driver/business truck so I have to leave it alone for now. When I get done with this I will try to draw up a diagram. I feel no need to make any $$$ off anyone, but I will definitely share what I learn along the way.
Bigblockmopar, my spare tire well is a little rusty on the wagon and will need to be cut out. My plan as of now is to cut it out and re-configure it to accommodate the mustang tank with a fuel injection pump. I’ve tried to find info about converting the push-buttons, but haven’t come up with anything definitive. If you have some info I am all ears. I would like to keep my factory fuel tank as well, might sound ridiculous, but here me out! I would like to put an electric fuel pump off the factory tank or somehow use the factory filler to fill both tanks. Just brainstorming on that one.
Never met a magnum that got better than 10 mpg. No idea why these were so thirsty.
