carkindaguy
i just finished my 360 build. i did not have any money left over for dyno time so i dont know what it makes as far as #s. i was wanting some help trying to estimate flywheel hp and torque. specs are as follows.from top to bottom.
holley ultra double pumper 750, stock out of box
eddy air gap intake, stock out of box
eddy heads stage 3 cnc ported by hughes engines, 2.08/1.60 valves, stock eddy valve springs.
flow 293.8/197.9 @ .600
milodon lifter valley baffle
hughes roller rockers,comp pushrods, lunati lifters.
lunati voodoo hyro flat 60404
milodon windage tray, stock oil pan.
tti stepped headers,2.5 exhaust, x pipe, electric cutouts, flowmaster 40 series.
mechanical fuel pump, water pump and power steering, electric fan, 165 thermostat aluminum radiator.
also if you have any suggestions for any changes or anything. its in my 74 street/strip duster with a 727, dennys driveshaft, dana 60 373 gears.
- Advertised Duration (Int/Exh): 276/284
- Duration @ .050 (Int/Exh): 234/242
- Gross Valve Lift (Int/Exh): .513/.533
- LSA/ICL: 110/106
