My 360 sounds like a sewing machine
Small Block Mopar Engine
  1. Dodge72
    Dodge72 Odd one out
    468
    289
    Feb 16, 2015
    Mason County, WA
    Local Time:
    9:55 AM
    So I finally got my 360 in my 72 Dart wrapped up abs took her on a maden voyage just around the neighborhood. Things were all good, oil pressure was good, temp was good, just a few things like timing and kickdown to be adjusted. Me being a little over cautious on my first engine build, noticed it sounded awfully like my solid lifter slant 6 previously: a sewing machine at idle to around 2000+ RPM.
    360, RV cam. Hydraulic roller (factory roller block, not Magnum)
    Stock non adjustable rocker shafts
    Custom length pushrods for 050" preload
    Stock Melling hydraulic rollers
    Stock valves
    Rebuilt iron heads, 9.5:1 compression.
    Oil I am using is Castrol 5w30 Dino oil. It sounds like it at warm, and most likely when cold (I honestly can't remember). Oil is definitely getting to everything. I might have a touch too much oil, like a quart extra(I'll have to drain it). I checked pushrods, all are rotating and are straight. I tried to push on the lifters and they felt solid : does this mean they are pumped up? Rockers didn't have excessive wear. Finally, I checked the valves with a straight edge and a flashlight... And there's light shining on the exhaust valves. With a feeler gauge, they appear to be 015" shorter than the intake, uniform between all of them. Could this be my issue? When I went to measure pushrods, I measured about 6-8 of both intake and exhaust and took the average. I know I've read many problems with hydraulic rollers, but it was mostly with retrofit stuff. I just want to make sure there's nothing wise I should check. Perhaps I should get some pushrods with an additional 015"? Engine sounds great otherwise, and the oil change after the initial run showed nothing but break in stuff.
    • Like Like x 1
    • 72Dart6pack
      72Dart6pack Harder Better Faster Stronger.
      3,572
      3213
      Feb 1, 2016
      Roseville Michigan
      Local Time:
      12:55 PM
      So now you have a 1972 Singer. Lol
      • Like Like x 6
      • Agree Agree x 3
      • Dodge72
        Dodge72 Odd one out
        468
        289
        Feb 16, 2015
        Mason County, WA
        Local Time:
        9:55 AM
        Ha!! It pairs wonderful with my 1906 Singer !
      • Plymouth 65
        Plymouth 65 Floorable Deplorable
        1,053
        952
        Jun 27, 2016
        Mich
        Local Time:
        12:55 PM
        Based on your information above you state 0.050 preload with stamped steel rockers. The statement that your exhaust valves sit about 0 015 lower than the intake valves. That should give you 0.035 preload on the exhaust lifters. I believe that should be enough but you may want to confirm with the lifter manufacturer. 65'
        • Agree Agree x 2
        • mopowers
          mopowers Well-Known Member
          4,718
          1824
          Feb 15, 2006
          West Sacramento, CA
          Local Time:
          9:55 AM
          What cam is it? Manufacturer?
        • Dodge72
          Dodge72 Odd one out
          468
          289
          Feb 16, 2015
          Mason County, WA
          Local Time:
          9:55 AM
          Yes that's correct, sorry if it was long winded. I am currently looking into it (PN JB-2225), but as far as I know they are a direct stock replacement and I cannot find any recommendation by Melling. I'll keep looking though.
          A reground cam. Here's the cam info....it's pretty mild.
        • pishta
          pishta I know I'm right....
          17,308
          6921
          Oct 13, 2004
          Tustin, CA
          Local Time:
          9:55 AM
          pushrods rotating...how? Rollers dont rotate. OR did you mean when you rotated them they didnt wiggle (showing a warp)? Run mechanical rockers, its not too late....
          • Like Like x 2
          • RustyRatRod
            RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
            60,809
            32468
            Jun 7, 2010
            Georgia
            Local Time:
            12:55 PM
            Verify you have the rocker shafts on correctly. There is a notch in the end of each shaft. That notch positions DOWN and to the REAR on the passenger's side and DOWN and to the FRONT on the driver's side. This can be a source of valve train noise if not properly installed.
            • Agree Agree x 3
            • Thanks! Thanks! x 2
            • MopaR&D
              MopaR&D Nerd Member
              4,176
              1021
              Jan 4, 2008
              Fort Collins, CO
              Local Time:
              10:55 AM
              IMO that oil is a bit too thin, I've also personally not had good results with Castrol oil but I don't think that's your issue.
              You mentioned there might be too much oil in it, if it's a quart over you'll definitely have noisy lifters from the crank whipping air into the oil.
              Lastly I don't know if it applies to the LA roller cam engines but I know on Magnums the spec for lifter preload is in the .080-.095" range, much more than a typical flat-tappet or aftermarket roller cam and lifters. They run fine with less but I've heard they do make valvetrain noise like a solid cam when set up that way. I put my 5.9 Magnum together with around .085" preload on the factory lifters and there is no valvetrain noise at all.
              • Agree Agree x 3
              • Billbo
                Billbo Well-Known Member
                85
                9
                Sep 25, 2005
                Australia
                Local Time:
                11:55 AM
                Use a thicker oil. At least 10W40.
                My engine seems a little noisier (valve train that is) with 15W40 as opposed to 20w50. 20w50 seems to be the good all round oil for me hear in oz.
                Regards
                Billy D.
                • Agree Agree x 2
                • QuickDart360
                  QuickDart360 Well-Known Member
                  1,150
                  406
                  Apr 5, 2014
                  San Antonio
                  Local Time:
                  11:55 AM
                  I would say 10/30 wt to be the minimum. I use 30 straight weight in my 360 and it's quiet.
                • Dodge72
                  Dodge72 Odd one out
                  468
                  289
                  Feb 16, 2015
                  Mason County, WA
                  Local Time:
                  9:55 AM
                  Thank you! I'll change the oil again and switch to a thicker weight (probably 10w-40) to see if that quiet things down. Cheaper than new pushrods. I'll have to check the rocker shaft orientation after work, I'm fairly certain that I places them correctly. Airways could have a d'oh! Moment .
                  I also have a aftermarket dipstick for the oil. Has anybody found these to be inaccurate or are they fairly reliable?
                • ocdart
                  ocdart Inland Mopars Car Club FABO Gold Member
                  9,894
                  2456
                  Nov 5, 2006
                  North OC, SoCal
                  Local Time:
                  9:55 AM
                  Best way to verify is during your next oil change.
                  Completely drain old oil and put in the exact volume designed for your oil pan, then check the level shown on the dipstick to see if it is at the 'FULL' mark.
                  • Agree Agree x 1
                  • krazykuda
                    krazykuda Well-Known Member FABO Gold Member How-To Section Editor
                    52,814
                    17802
                    Aug 20, 2007
                    Orland Park, IL
                    Local Time:
                    11:55 AM
                    What a coincidence, my sewing machine sounds like a 360.... :D
                    • Like Like x 1
                    • 66jim
                      66jim Well-Known Member
                      475
                      449
                      Dec 11, 2007
                      NE PA ie pennsyltucky
                      Local Time:
                      12:55 PM
                      Remove valve cove check pushrods for looseness, reground
                      cams remove material from base circle of cam to increase lift and duration. But 203-205 is pretty small so not much was removed?
                      • Like Like x 1
                      • thesiren74
                        thesiren74 Well-Known Member
                        1,233
                        814
                        Feb 23, 2014
                        kenosha,wi
                        Local Time:
                        11:55 AM
                        Get longer pushrods, i had to do that .030" longer.
                        • Agree Agree x 1
                        • Bad Sport
                          Bad Sport HALF A BUBBLE OFF Staff Member FABO Gold Member
                          37,483
                          18101
                          Jun 12, 2010
                          The Wolverine
                          Local Time:
                          12:55 PM
                          I would, if'n they aren't oriented correctly you will be a bit dry on the top, lol.
                        • nm9stheham
                          nm9stheham Well-Known Member
                          12,090
                          3931
                          Dec 20, 2013
                          Waynesboro, VA
                          Local Time:
                          12:55 PM
                          As above... IIRC, the lifter preload on rollers is typically more than for flat tappet hydraulics. That .015" on the exhaust valves works out to .010" on the pushrod side, so that is not a big difference, IMHO.
                          Lifters sounds pumped up if they feel solid. BUT you have to rotate the engine around a few times to test each lifter when it is a zero lift to make this a valid test. A lifter leaking down but up on the cam will go solid due to the piston fully being depressed in the lifter body.
                          I like the flow of lighter oils and raced on Castrol for a long time, but the thinner weights to tend to make more hydraulic lifter noises. (I personally will live with a little noise to have more oil flow. But different things bother different folks....)
                        • Dodge72
                          Dodge72 Odd one out
                          468
                          289
                          Feb 16, 2015
                          Mason County, WA
                          Local Time:
                          9:55 AM
                          Got to it this afternoon finally.
                          And despite my paranoia, I had put the driver's side rocker shaft on backwards! D'oh! Moment for me . It looks like there was still oil getting up there from the pushrods (they are oil through) and nothing was galled. I fixed that, and put only 5 quarts of 10w-40 in there (dipstick read full) . Man did that quiet everything down! Cold or warm, all I hear now is the carb sucking air and my clutch fan...and of course, my exhaust. :) Thank you to the replies.
                          • Like Like x 5
                          • nm9stheham
                            12,090
                            3931
                            Dec 20, 2013
                            Waynesboro, VA
                            Local Time:
                            12:55 PM
                            Glad it was so simple!
                            • Like Like x 1
                            • RustyRatRod
                              60,809
                              32468
                              Jun 7, 2010
                              Georgia
                              Local Time:
                              12:55 PM
                              I doubt the oil weight did anything for it. Likely was the rocker shaft on incorrectly. Glad you got it at any rate.
                              • Like Like x 1
                              • Dodge72
                                Dodge72 Odd one out
                                468
                                289
                                Feb 16, 2015
                                Mason County, WA
                                Local Time:
                                9:55 AM
                                I agree, something like that probably caused most of the rukus. Fortunately , oil is cheap enough that I can switch back to a lighter weight and see if it'll keep the silence.
                              • RustyRatRod
                                60,809
                                32468
                                Jun 7, 2010
                                Georgia
                                Local Time:
                                12:55 PM
                                If it doesn't stay quiet when you switch back, somethin's WRONG.
