Dartfreak75
Restore it, Dont part it!
I am gonna have to get me some c channel stock to clamp down as a jig I tried using angle iron it just wont hold straight.
The thickness is 1/4 I will try will add more bevel and slow the speed down and try it again that's why I cut that piece to practice on I'm a noob at welding so I wanted to get some practice before the real things it's a harbor freight 125 flux core welder the heat is all the way up. I'm a little concerned it's not gonna be enough welder for this job but I'm gonna give it a try! Thanks alot guys for your advice I truly appreciate it!I agree with those welds appearing cold. Turn up the amperage, or turn down the wire speed. And I'd also grind a larger bevel in the joint to ensure 100% penetration. Don't be afraid to make a couple passes too.
How thick is the wall thickness of those tubes? What welder are you using? Sorry if you've already stated - I couldn't find it.
Thank you I will give that a tryPull both sides back another 1/8". Heat all up and wire speed down a notch
Not quite 1/4" on the tubes. Its closer to 3/16" wall thickness.I agree with those welds appearing cold. Turn up the amperage, or turn down the wire speed. And I'd also grind a larger bevel in the joint to ensure 100% penetration. Don't be afraid to make a couple passes too.
Maybe a stupid question but just a thought would it help to heat up the metal with torch right before I started welding would that help at all? Or does the wire itself need to be hotter?Pull both sides back another 1/8". Heat all up and wire speed down a notch
Yea I planned on doing that. I'm not sure why they aren't from the factoryThe axle tubes need to be fully welded to the center also.
Basically what you need to do with a 12 bolt Chevy you need to do to a 8.8 Ford.
And yes I have seen the center of a 12 bolt Chevy break free and point strait up on a 12 second 4 speed Nova.
These are the Lincoln wire at the same speed. And the contraption I built lol
How do these welds look? Better?
Thank you. I really appreciate the advice. I can tell a big difference with the Lincoln wire like you said I can actually see the puddle. Before there was so much splatter I couldnt really see much.Showing some progress there. There is one big tip that often does not get brought up. Be sure you an see the puddle! Seems pretty basic, you'd be surprised how much better your welds will be. I would also recommend you clean the entire weld area before you start burning wire. A flap disc on your angle grinder will make quick work of it.
The angles is something I'm having trouble with. I cant seem to be constant. What angle do you recommend? And how far away (how long my wire) should I be with the tip. About 3/4 of an inch seems to run a smoother bead but the closer I get the better i can see the puddle.The 4 Key Points of Welding:
Heat
Angle
Distance
Speed (of travel, and/or wire speed)
Coordinate all of these together and you can get perfect looking welds. Gravity plays a part too pulling on the molten puddle as you are moving along.
As Gearhed73 stated above, clean up the axle tubes before welding . . get the rust off. It will be a stronger more pure weld and won't spatter so much.
