Dartfreak75
Restore it, Dont part it!
Yea you are right there. I do wish I had more money to put into it iv already put alot more in it than I had planned it was supposed to get cleaned painted new cam and lifters and go in the car without even disassembling it but I decided to port the heads to try and get some more power and found all sorts of issues when I pulled the heads off. Good thing I did tho I'm sure it wouldn't have lasted long the way those valves look among other things. If I had the money i would take it to the machine shop and have it punched out .03 turn the crank align honed and have a set of kb167 pistons fitted and balanced. But I just dont have the funds.I know it's like where does the cheap insurance stop or start though? It's almost like you could say that at every step. Like it would be cheap insurance to prep the block properly instead of just honing it and trying to put bearings in yourself and get it clean enough to take paint and get all the oil galleys and water jackets all clean properly. do you have the crank turned or do you just slap me bearings in there? It would be cheap insurance to have it turned and get oversize bearings? It's like you got to take it all apart and make your decisions where you want to have cheap insurance or where you don't? I always like to put my insurance into the bottom end. Then again all it takes is one part in the top-end to fall asleep LOL and there goes your bottom end! LOL
