hemiDenny sent this thread to me as a guide for installing the front suspension and K member he is building for my 66 Cuda. Awesome thread and i thank you for the great job putting this together! I have a question for you on the brake setup you have. I am planning to put the Willwood on all 4 corners, can you tell me what proportion valve and master cylinder works best with that setup? I am currently set up with disc on the front drum on the rear, i do have a valve on the system and a dual reservoir master. I see you have a nice looking bracket for the proportioning valve, looks great. i appreciate any help. Your car is awesome. That undercoating looks amazing as well, did you have to strip the underside of the car? Thanks for the great work!got the engine fully dressed and ready to go back in. just have to get the trans cleaned up so i can install it with the engine.
then i started installing some of the other pieces i got back from powder coat. here is my brake prop. valve mount installed on the driver side inner sub frame connector
then i got my drive shaft loop back in. notice how it bolts to both frame connectors and has holes for the inner seat bracket bolts. ties the frame, floor and seats all together.
Ok I used a master cylinder spec'd for a late 80's dodge Dakota. 15/16" bore I believe. I then installed an adjustable proportioning valve in the rear brake line. I did strip the underside of my car by hand, on my back with a wire wheel,putty knife and enough beer to kill a race horse lol.hemiDenny sent this thread to me as a guide for installing the front suspension and K member he is building for my 66 Cuda. Awesome thread and i thank you for the great job putting this together! I have a question for you on the brake setup you have. I am planning to put the Willwood on all 4 corners, can you tell me what proportion valve and master cylinder works best with that setup? I am currently set up with disc on the front drum on the rear, i do have a valve on the system and a dual reservoir master. I see you have a nice looking bracket for the proportioning valve, looks great. i appreciate any help. Your car is awesome. That undercoating looks amazing as well, did you have to strip the underside of the car? Thanks for the great work!
Ed
Send me some picks of that new rolling jack and also of the car. I would love to see what you are working on. ThanksI got my set up from Denny a couple of weeks ago. I have it painted and ready to install in my 69 Dart drag car. Monday I was able to buy a rolling jack for my 4 post lift and it should make the install a lot easier. Looking forward to a better steering car with hopefully more weight transfer to the rear. Like Young Gun the undercoating removal before I had the lift wasn't much fun laying on my back using a heat gun, scrapers, wire brushes and wire wheels. Then cleaning all the remnants with solvent and lots of rags.
younggun, your thread has been a big help to me during my HDK install, thank you. I'm at the point of spring selection now. I was wondering how you've liked the 500# springs now that you've had it on the road. How is the ride/handling?Got some more toys today! Got DD403 double adjustable 10" double adjustable coil over shocks. Got 10HT500 springs. 500lb 2.5 ID 10" springs.
350 lbs. with aluminum engine components is more like it. I don't think I would even
want 400 pounders unless you were using an all iron big-block. JMHO
how much was the steering shaft and u joints? is there a cheaper option than through denny? he has a shaft and u joints but it's $225ok guys, sorry for the delay but here is the steering shaft istall.
my steering column has been converted to 3/4" DD shaft on the end for quite some time now so there was no need for any machine work. I installed a flaming river steering universal joint from the column to a short chunk of stainless double D shaft. I then installed another universal joint from the steering rack to the double D shaft. the steering rack is 9/16x26 spline.
When ever your using DD steering shaft and universal joints it is critical to drill small indents into the steering shaft so that the set screws have a place to land.
IF YOU SKIP THIS STEP YOUR CAR WILL EXPLODE AND BE CONSUMED WITH FIRE.
I got my parts from summithow much was the steering shaft and u joints? is there a cheaper option than through denny? he has a shaft and u joints but it's $225
Summit /Atech is where I get them too....I will supply the part numbers and /or specs.
You could always check e bay......occasionally, I see components on there at half the price..
or eliminate the vibration dampener (most expensive piece) and just use a u -joint.
Denny is great to work with and almost always answers when you call or he'll get back to you very quickly. I really enjoyed just shooting the bull and bouncing ideas off of him. All around great guy and there to help. And the best thing of all, my car actually feels safe to drive on the streets now after installing his kit. I can shut the car down quick and it stops straight as an arrow. It wasn't at all like that with the factory setup.
i can appreciate a guy that will stay in touch with his customers. Ive emailed denny several times in the last couple weeks and he almost always responds by the end of day or first thing the next day.
