I’d sand roll it a littleWhat if anything can be done with the plug hole? Kim
the factory head has a recess so that plug come out square
Nor have I heard of anyone doing anything different about it. Let's be fair, people have been running OOTB Edelbrocks for a lot of years now, and no issues reported? Hmmmm……Seeing the plug hiding down in a hole would make you think it would require a different heat range...................But even the Eddy, and now the trick flows.........and i have not heard anyone make any statement about XYZ head needing a different heat range
I think on these that something should be done. That’s just to far in for my liking. Sand roll as stated or a light dressing with a Dremel and carbide bit? Or is that to aggressive? KimNor have I heard of anyone doing anything different about it. Let's be fair, people have been running OOTB Edelbrocks for a lot of years now, and no issues reported? Hmmmm……
P.S. - I just ran a plug in mine, and of course the same results...
I guess I'll see what some here come up with. I don't think SM is any worse than the Eddies. Not saying it's right, but people have been bolting on OOTB eddies for 25 years ?? Not one issue reported due to plug location to my knowledgeI think on these that something should be done. That’s just to far in for my liking. Sand roll as stated or a light dressing with a Dremel and carbide bit? Or is that to aggressive? Kim
Agree, it’s just there’s two ends of the spectrum (install ootb and full tilt porting job) but a massive expanse between where anyone can do from just a little to a lot more. This is simply an attention to detail issue and an easy cleanup job at that. If you had your choice of an early version and latest version of these heads and a nice dressing to the hole was the difference, what head would you rather have ootb?Nor have I heard of anyone doing anything different about it. Let's be fair, people have been running OOTB Edelbrocks for a lot of years now, and no issues reported? Hmmmm……
but you ran them like that for a while, correct? for sure there is opportunity for improvement, but certainly we are not the first to discover this.... Can't be ..The picture I just posted above of my Edelbrock heads went 9.70’s at 2800 pounds. I will be making some mods with a carbide burr and sanding roll before they go on my next build.
Id knock the ground strap off a plug, install it, then contour and polish the hole with a coarse sanding roll and not worry about rounding the threads deeper in.I think on these that something should be done. That’s just to far in for my liking. Sand roll as stated or a light dressing with a Dremel and carbide bit? Or is that to aggressive? Kim
lol.... before I read this I already knocked the strap and porcelain from the end of the plug. I think I'll just remove the threads that are remaining. Might go to work right now....Id knock the ground strap off a plug, install it, then contour and polish the hole with a coarse sanding roll and not worry about rounding the threads deeper in.
I only noticed those edges when I gave my set a thorough rectal exam. Then when I got the TF’s I noticed the detailing so no, somebody else has been there.....well versed in being up to their elbows likely hitting teethbut you ran them like that for a while, correct? for sure there is opportunity for improvement, but certainly we are not the first to discover this.... Can't be ..
TOO LATE!!!! AREADY STARTED, LOL..... I'll post my results in a few... LOL.I only noticed those edges when I gave my set a thorough rectal exam. Then when I got the TF’s I noticed the detailing so no, somebody else was already up to their elbows likely hitting teeth
There may be other things to consider.
I'm just spitballing here but i can see the plug needing some kind of protection.
Now stay with me here. what if there was some kind of Wet Flow situation were fuel would puddle in that area and so they made a hat, so to speak so the fuel rolled on by, instead of puddling. now if you moved the plug out more like toolmanmike suggest......................just thinking out loud here........
No matter what, i would be removing any sharp edge from the combustion chamber!
And if they were corrected how much of a difference would it make? As long as it's not causing a problem.As has been mentioned...... these are copies of Ede heads.
The plug holes are done that way in the RPM heads, and since that’s the head they copied...... the threads are the same in the SM heads.
My guess is over 95% of the sets in use have not had anything done to the plug holes.
