about "3 sputters out of the hole" away..... LOL. Get rid of that and I'll punch into the 14's no problem...Low 15s......awesome!
14's are within reach! !!!!
Jeff
Just think, you have good things in your future with your headers, 3.55's, and aftermarket converter. I think if I get my 60 ft. down to even a 2.20, I'll be running 14.80's with ease. cough, sputter eddy, cough.... lol.$499 in a 318......damn good!
I remember reading that.....that was a great read!You make me want to revisit my "Duster on the Cheap" project again.
Are you thinking high 13's at about 100 mph for you??? I am ....
Drive it. No plans to sell it. Not a stitch of rust underneath, and it's just too hard for us in the rust belt to get them like this here. They are either done and expensive, or pure parts cars.What are your plans for the car?
Daily driver. ....flip it ???????
Jeff
-- I love the highway gears. Engine is relaxed going down the road at 60 mph. We drove it 1 hour to the strip today, and of course 1 hour home. Runs nice and cool, didn't use a ton of gas, just a fun ride.
But I'm going to be a tweaking as time permits.... I'm going to push the mph up and knock the E.T. down.
Manufacturer Original Sales Brochures*This project assumes you already have dual exhaust. If not, that will be must before you start*. I'm doing it with manifolds, no headers.
Budget is to stay under 499.00 for all purchases including gaskets.
Goal here is simple. Most factory muscle cars in the late 60's to early 70's are well documented to have run between 14.20's - 15.60's. I want to run in the middle, high 14's. The target of my goal is to run with a factory '73 340 Duster. They have been well documented to run low 15's with auto and 3.23 gearing. With slicks they hit high 14's, and this is my target.
Thanks man. The car went before it was time.I remember reading that.....that was a great read!
Jeff
Words of wisdom,here...I used to tune the old stuff in (big cams,no compression,no gear/converter..) The car ,I enjoyed the most: A well set up low buck chassis /used 360notchback Cuda. Sold it,it ended up running 13:60's @ 101-102.....A small 200/204 @.050,7.8 compression 360......Hopefully it push most people in the right direction.
Problem is most of us don't know what we want and automatically pick without thinking that we need a 400-450 hp 12 second car. Which requires a complete over haul of the whole car. A more reasonable goal is 13.5-14.5 (250-350 hp) which is more than enough to keep up with most muscle car old or new.
And can brake it down to weekend projects that will keep on putting a smile on our face after each step. Instead of I just put a Huge *** cam in and runs like **** but wait until I do thsee 3 more mods and she be real fast and even after its all done probably have a car you don't want to drive much.
Thanks... yeah, I do have the hole for the spring in the linkage, but I don't have the right spring.... LOL. Throttle is coming wide open for sure. Yes, the 70 340 Duster with 3.55's would be quicker than the '73 340 Duster with 3.21's. I think the 70 340 Duster with 3.55's was around 14.40's/96 mph. I have other carbs to put on it, it's just I was trying to work with the "low dollar" bargains.... LOLThis really is a interesting thread. Doing more with less, gotta love it.
One thing that I seen is the spring pulling your kickdown lever should go from the cable stud back to the bellcrank arm by the firewall. There is a little hole in it for the spring. Of course linkages are different through the years, so I might be all wet.
As it is now you might not get full throttle opening on the carb.
From what I read, 70 340 Dusters with a 3:55 gear ran 14:70's. You're right there with a carb tune.
To bad your not closer, I'd let you use my 650 Eddie carb.
Mighty kind words, 360DartGT66. Thanks Just trying to offer something for the new guy with a 318 2bbl that has no money. Too often they are told unless they have 2000 dollars and a 360, they can't play.One of the best threads I've seen in a long time. Thank you, 318willrun!
I'm just as excited to see how your car runs too, Jeff!!It's because of this thread that I went from a Krylon Rebuild to actually getting in there and doing something with my 318!
Porting my heads was actually FUN!
Thank you 318willrun for a great thread and a TON of inspiration!
Jeff
My family and I are on vacation this week. I'll get back to the Duster, but I got a lot to do and will I be busy when I get back... but I'll find a few minutes here and there....Anything new to add. How's the tuning going?
