340dartley
- Joined
- Feb 4, 2007
- Messages
- 519
- Reaction score
- 170
I have a couple of other threads here but they were subject specific. This thread will touch on some of the issues but will hopefully be able to grow with the evolution of the motor and car.
First off here are the specs on my car and motor.
1969 Dodge Dart Swinger. 340 automatic
.030 340 with forged 10.5 to 1 pistons
X heads with some bowl work and port matching.
Stock rocker arms and push rods.
Stock intake
750 dp carb
Mopar purple cam .508 lift 292 [email protected] duration
Bottom end was lightened and balanced
I drove the car to a 12.0 quarter mile time at Bakersfield back in the early 90s. I was not the owner of the car at the time.
I purchased the car back in Oct of last year. I have yet to make a pass with it as life sometimes gets in the way. The previous owner told me to shift at 5200 rpm as it pops at any higher rpm.
I was told it should probably have new valve springs installed.
I also just purchased an Edelbrock performer rpm manifold and would like to get a bit more high rpm performance.
I started looking for valve springs and found the options limited in my budget.
Well tonight I removed the valve cover to see what I had to work with. I was surprised to find a double valve spring with a damper already installed.
This brought up 2 things. If I upgrade the springs I already have the keepers and machine work done so I can just put them in. The other thing is wouldn't double spring even if worn be able to control the valve train past 5500 rpm. Maybe there is another issue.
Stock intake
750 dp carb
