If you put a two piece 73 bushing set with the collar on a early strut rod you will move you LCA's back 1/4 inch. the collar is built on the early struts and the nut tightens to that. With the 73 collar on the early bar you will not get the pin in the bar in front of the nut and cupped washer. The later bars are shorter then the early bars flange to flange comparison. To allow the room for the two piece bushing set with collar. If you want I can post the difference but some of you would have your own reason why your incorrect install is correct anyway. Do like the last guy I tried to explain this to. cut the bushings and the collars to fit. If you look close in the dark maybe there is a line to cut them to make them universal fit for all years.
They do make a two piece bushing set for the early bars they are alot smaller and get no collar. They also are not as stable as the one piece.
