scott hoffman
Im no electrical expert, butI would go back and read the very first comment from 318Willrun, my 340 Roadrunner was doing the very same thig you are describing. we trouble shot for HRs, low spark, used the spark light between the plugs and the wires low spark, I called a friend who is a Cheby guy he found it is like 5 minets after lightly splitting the wire case on the Nutral Safety switch, rite at the connector there were two broken wire connections, funny he said mopars are noted for this i never heard that before but some how he knew.Karl, I think you need to re-do your grounding. The low voltages is a tell-tale sign.
You can have continuity but still have poor current capacity. In other words, you need to clean off the contact surfaces where the ground strap is bolted as well as the other ground points.
And I'm not sure the intake is the best place to ground. Remember, what the ground strap is really for is the starter and it's bolted to the block. The intake is bolted to the heads so the current has to go through the bolts only since there are gaskets everywhere. Normally, a torqued bolt only holds by the first 1.5 thread turns. With a little grease or thread lock, the conductance can be severely diminished.
If I were you, I'd go over all the grounding surfaces and clean off the paint and apply some copper paste. If you still want the ground strap to connect to the intake, I'm afraid the paint will have to come off.
Also, I don't really see the point in having two connections to chassis. The 10Ga is either redundant OR it is the best connection to ground in which case it is insufficient which will cause low voltages everywhere, especially when cranking.
