Frnknsteen
21" manifold
4" ported
3000
22" manifold
11"ported
21" manifold
4" ported
3000
22" manifold
11"ported
Compression test will also indicate how radical the set up is. A more radical cam will have lower compression pressures. This is because the cam has the valves open longer to pack in more air at high rpm. But at low rpm it reduces the pressure you'll measure. A higher static compression will offset this somewhat. Bottom line, its a helpful indicator.I'm planning to do a compression check of all the cylinders. I know that won't tell me the compression ratio, but it will tell me how even the motor is from cylinder to cylinder, and tell me how much air I'm moving and if I'm low, like 110psi or doing ok, like 150 - 160psi. .
Cool. How far you go just depends how much disassembly you want to get into. If the harmonic damper is stock mopar diameter, the Mopar Performance timing tapes with white lettering on black background are nice to use. That, a dial indicator - and if you really want, a solid lifter, you can measure all of the cams' characteristics. Or you can just try to get .050 intake and exhaust timing and from that look at Compcams catalog.You make a good point on degreeing the cam. It wouldn't take me long to get down to that point and then I would at least know what the cam is. I was wondering if there would be markings on the end of the cam listing part# so I could tell what it i
Perfect. Only suggestions are to note RPM at initial timing, and if to plug the vacuum hose with a golf tee or similar (if you haven't been).Timing according to my light is 13 initial (vacuum disconnected), 33 with mechanical advance only (vacuum disconnected) at 2600rpm, 50 at 2600 with vacuum attached to manifold vacuum port.
This suggests to me that the cam is not terribly radical. Hence my suggestion for 15-16* initial. (Manifold vacuum at idle will go up with the increased advance. This is good - it makes tuning easier)Engine vaccum at idle hovers between 12 and 13 (connected to manifold vacuum port).
Perfect. This shows the throttle blades are close to their intended position at idle.I connected to the ported vacuum and no vacuum at idle. Vacuum jumps when I blip the throttle.
Agreed. This advance canister must be adding 4* at 13" of vacuum. Going to ported vacuum for the advance control as you've done is generally the easier and better approach for a hot rod. (But in some situations it turns out that it is better to use manifold source. The right way is whatever the engine wants. )Interestingly, timing at idle with manifold vacuum connected is 17, meaning it is not giving full vacuum advance at idle like I thought it would.
Need to know the vacuum as well. Then if you plot out the mechanical advance curve so you have the timing w/o vacuum at 2600, you can figure out the vacuum advance contribution.Timing at a steady 2600 with vacuum connected to ported vacuum is 37.
Yes it may.Do you think it may want more initial and less advance?
The secret here is to remove the vacuum advance (and plug it) when working with the mechanical. Just measure the timing (without vacuum) from the lowest rpm through 3000 or so. If your racing, you'll want to check it a little higher, but for now, don't worry about it.Should I try pulling the vacuum advance and going back to straight mechanical, then give it a little more initial?
Absolutely fine. Expect that the mix screws will be further in with four corner idle on a stock or mild cam. The manifold vacuum at idle is stronger (pulls harder) than a more radical engine.I did find it interesting that the book said to start at 1.5 turns out, but carb was set to 3/4 turns out. I adjusted them out approximately 1/4 turn more (1/8 turn at a time each) before vacuum started to drop off. Reset them back to max vacuum where it started to drop.
If that's a steady full throttle pull in 3rd (or 4rth), the fueling doesn't look right to me. It should be much flatter, staying within 12.8 to 13.2 AFR on racing gasoline and probably a little richer on street fuel.
Yes.Can there be gains in increasing the jets if the A/F ratio is already running in the 12-14 range? Wouldn't it go rich if jets are increased?
I can't answer this. Depends on how it was built. Most of the time dyno operators take it until rpm stops climbing. Depends on what you are doing. Your choices seem quite reasonable. Its not the max hp you're after. Its whether the changes made are improvements in rpm range you've run it. Perfect.Dyno runs were from about 2000 rpm up to just under 5000 rpm. We didn't push it above 5000 rpm because we didn't know much about the motor yet and didn't want to push it too hard. Out of curiosity,... what is safe redline for these big blocks? I've always heard don't push it over 5500 for very long.
Well, You're going to have to do Your own detective work here.I don't recall off the top of my head what the actual vacuum was reading, but yes, it was pretty steady. I remember thinking it was a little low, but I don't remember if it was around 11 or 13. I want to say it was running around 11 inches because I don't think I would have thought 13 was low. Borderline maybe, but not low. At the time, I wasn't really thinking about specific numbers. I was just tweaking the four mixture screws a little at a time until max vacuum was reached, to make sure they were all set evenly (as per my handy dandy "Tuning Demon Carburetors" book!).
I will run back to the shop and check vacuum tonight. It's about 25 degrees colder today, but I'll let her warm up good and check it quick.
Yes,... he clearly said they rebuilt the motor, but it sounded like he had a shop do the rebuild because when he was talking about the engine he specifically said "They did some machine work and put in a bigger cam" not "I" or "We"
13* at 600 or 800 rpm would be good for a stockish cam.
With a hot cam, the engine will probably like a bit more advance. With a manual transmission, its harder to test idle under load. OTH its not as important. But if its a little 'lazy' or wants to die when you gently slip the clutch, these suggest a little more initial advance would be good.
Try 15* or 16*
Another way is to use a hand operated vacuum pump (eg Mityvac) while the engine is idling.
a. Driving at a steady highway speed (with rpm between 2000 - 4000) note the max engine vacuum.
b. Back at the shop, set up the timing light and a vacuum pump attached to the vacuum advance. Bring the engine to the 2600 rpm and the vacuum pump to the vacuum found in step a. See what the timing is. For an B or RB engine, they recommend 56*. Adjust the vacuum pod as needed.
1) As dukeboy_318 said, those are some lame-*** lo-po mills stock, and just putting a set of blue Felpro's on would likely drop the OE squeeze below 8:1. So unless that
things got better slugs or they whacked the 906's a ton, that's where the lazy lies. If they did whack the heads, look for the slightly raised portion of the intake surface to
be almost gone, assuming they cut the intake face to maintain the manifold alignment/height. Do a warm compression check, throttles wide open, see what You've got.
Great. 750-800 rpm idle is decent for a motor with some cam.Yes, vacuum ports were capped off while checking initial and full mechanical advance at 2600 (33*)
RPM was about 750-800 RPM idle while checking initial.
That makes sense. Now if you increase the initial timing to 16*, that should make the car less lazy, and you may find the engine prefers ported.Actually,... the vaccum advance was connected to the ported vacuum when I bought it, but it didn't run as well this way and ran hot. I have it connected to full manifold vaccum port now. It seems to run better and it is running cooler at idle and cruise now.
T Vacuum at the ported is manifold vacuum. The difference is only at idle. The ported vacuum comes from a hole just above the throttle blades in closed position. As soon as the throttles crack open, that port is exposed to manifold vacuum. Since there is no choke, you can see it easily by taking the hose off and squirting some carb cleaner in the port. Just be super carefull not to get that stuff in your eyes when looking down the primaries! Goggles are a good idea.I will have to get a vacuum T so I can check vacuum at ported vacuum port,
Maybe I need to read back to an earlier post. So forgive me if I'm misunderstanding.but I know the mechanical advance is at 33* without vaccum attached, so wouldn't my ported vacuum be contributing 4* at 2600 if the total timing (when connected to ported) was 37*?
Take some photos looking down as well as from the sides. I won't be able to tell you the model, but more important, we can see what type of boosters and adjustibility it was made with.It looks like a Road Demon or Speed Demon. It has a choke horn, but no choke installed, and mechanical secondaries.
Take some photos looking down as well as from the sides. I won't be able to tell you the model said:Regarding the 4 dyno runs shown.
At what rpm was throttle fully floored?
I ask because the red run looks like it could have been part throttle to 3700 ?
That would be a perfectly normal explanation for the AFR going so lean before rich.
But then why would the dark blue or black run be so different? Was the throttle brought on much more agrssively?
Are you sure it stopped advancing at whatever RPM point you stopped?
This is usually a HUGE error when tuning. Run the RPM up until it stops advancing, not some number picked from a recommendation or guess. It may have more advance in it than you are seeing.
Not enough initial timing is the first thing I see and would attack.
Define lazy......What are you used to driving? lol.
(torque x rpm)/5250 =hp
Working it backwards, I see you have available 292 ft lbs at 2250rpm. NET 292.
That's more than a 69 340 can muster at peak.
That's more than my HO360 can put out until nearing 4000, And there is NOTHING lazy about my 360.
Do the compression test, then you'll have a better idea of what's going on.
Now why in the world the dyno operator would set the power timing to 45* all-in-including-the-can, is a mystery to me.Only he would know why.
I'm still trying to figure out why you would state this combo with an A833, assuming it's in an A-body, is lazy,lol.
>Looking at the dyno-chart, she looks to have a nice fat midrange. If you converted that back to torque, I think it would actually look pretty healthy in that zone.You can do that using this formula, which is the same as the first but just rearranged to spit out torque.
I really have nothing to compare to determine if I should be happy with the output for this cruiser, or if there are some little things I could do to wake it up a bit.
For those of you interested.......
This was written by a former GM engineer as a response to a similar question on a Camaro board:
As many of you are aware, timing and vacuum advance is one of my favorite subjects, as I was involved in the development of some of those systems in my GM days and I understand it. Many people don't, as there has been very little written about it anywhere that makes sense, and as a result, a lot of folks are under the misunderstanding that vacuum advance somehow compromises performance. Nothing could be further from the truth. I finally sat down the other day and wrote up a primer on the subject, with the objective of helping more folks to understand vacuum advance and how it works together with initial timing and centrifugal advance to optimize all-around operation and performance. I have this as a Word document if anyone wants it sent to them - I've cut-and-pasted it here; it's long, but hopefully it's also informative.
TIMING AND VACUUM ADVANCE 101
The most important concept to understand is that lean mixtures, such as at idle and steady highway cruise, take longer to burn than rich mixtures; idle in particular, as idle mixture is affected by exhaust gas dilution. This requires that lean mixtures have "the fire lit" earlier in the compression cycle (spark timing advanced), allowing more burn time so that peak cylinder pressure is reached just after TDC for peak efficiency and reduced exhaust gas temperature (wasted combustion energy). Rich mixtures, on the other hand, burn faster than lean mixtures, so they need to have "the fire lit" later in the compression cycle (spark timing retarded slightly) so maximum cylinder pressure is still achieved at the same point after TDC as with the lean mixture, for maximum efficiency.
The centrifugal advance system in a distributor advances spark timing purely as a function of engine rpm (irrespective of engine load or operating conditions), with the amount of advance and the rate at which it comes in determined by the weights and springs on top of the autocam mechanism. The amount of advance added by the distributor, combined with initial static timing, is "total timing" (i.e., the 34-36 degrees at high rpm that most SBC's like). Vacuum advance has absolutely nothing to do with total timing or performance, as when the throttle is opened, manifold vacuum drops essentially to zero, and the vacuum advance drops out entirely; it has no part in the "total timing" equation.
At idle, the engine needs additional spark advance in order to fire that lean, diluted mixture earlier in order to develop maximum cylinder pressure at the proper point, so the vacuum advance can (connected to manifold vacuum, not "ported" vacuum - more on that aberration later) is activated by the high manifold vacuum, and adds about 15 degrees of spark advance, on top of the initial static timing setting (i.e., if your static timing is at 10 degrees, at idle it's actually around 25 degrees with the vacuum advance connected). The same thing occurs at steady-state highway cruise; the mixture is lean, takes longer to burn, the load on the engine is low, the manifold vacuum is high, so the vacuum advance is again deployed, and if you had a timing light set up so you could see the balancer as you were going down the highway, you'd see about 50 degrees advance (10 degrees initial, 20-25 degrees from the centrifugal advance, and 15 degrees from the vacuum advance) at steady-state cruise (it only takes about 40 horsepower to cruise at 50mph).
When you accelerate, the mixture is instantly enriched (by the accelerator pump, power valve, etc.), burns faster, doesn't need the additional spark advance, and when the throttle plates open, manifold vacuum drops, and the vacuum advance can returns to zero, retarding the spark timing back to what is provided by the initial static timing plus the centrifugal advance provided by the distributor at that engine rpm; the vacuum advance doesn't come back into play until you back off the gas and manifold vacuum increases again as you return to steady-state cruise, when the mixture again becomes lean.
The key difference is that centrifugal advance (in the distributor autocam via weights and springs) is purely rpm-sensitive; nothing changes it except changes in rpm. Vacuum advance, on the other hand, responds to engine load and rapidly-changing operating conditions, providing the correct degree of spark advance at any point in time based on engine load, to deal with both lean and rich mixture conditions. By today's terms, this was a relatively crude mechanical system, but it did a good job of optimizing engine efficiency, throttle response, fuel economy, and idle cooling, with absolutely ZERO effect on wide-open throttle performance, as vacuum advance is inoperative under wide-open throttle conditions. In modern cars with computerized engine controllers, all those sensors and the controller change both mixture and spark timing 50 to 100 times per second, and we don't even HAVE a distributor any more - it's all electronic.
Now, to the widely-misunderstood manifold-vs.-ported vacuum aberration. After 30-40 years of controlling vacuum advance with full manifold vacuum, along came emissions requirements, years before catalytic converter technology had been developed, and all manner of crude band-aid systems were developed to try and reduce hydrocarbons and oxides of nitrogen in the exhaust stream. One of these band-aids was "ported spark", which moved the vacuum pickup orifice in the carburetor venturi from below the throttle plate (where it was exposed to full manifold vacuum at idle) to above the throttle plate, where it saw no manifold vacuum at all at idle. This meant the vacuum advance was inoperative at idle (retarding spark timing from its optimum value), and these applications also had VERY low initial static timing (usually 4 degrees or less, and some actually were set at 2 degrees AFTER TDC). This was done in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it.
If you look at the centrifugal advance calibrations for these "ported spark, late-timed" engines, you'll see that instead of having 20 degrees of advance, they had up to 34 degrees of advance in the distributor, in order to get back to the 34-36 degrees "total timing" at high rpm wide-open throttle to get some of the performance back. The vacuum advance still worked at steady-state highway cruise (lean mixture = low emissions), but it was inoperative at idle, which caused all manner of problems - "ported vacuum" was strictly an early, pre-converter crude emissions strategy, and nothing more.
What about the Harry high-school non-vacuum advance polished billet "whizbang" distributors you see in the Summit and Jeg's catalogs? They're JUNK on a street-driven car, but some people keep buying them because they're "race car" parts, so they must be "good for my car" - they're NOT. "Race cars" run at wide-open throttle, rich mixture, full load, and high rpm all the time, so they don't need a system (vacuum advance) to deal with the full range of driving conditions encountered in street operation. Anyone driving a street-driven car without manifold-connected vacuum advance is sacrificing idle cooling, throttle response, engine efficiency, and fuel economy, probably because they don't understand what vacuum advance is, how it works, and what it's for - there are lots of long-time experienced "mechanics" who don't understand the principles and operation of vacuum advance either, so they're not alone.
Vacuum advance calibrations are different between stock engines and modified engines, especially if you have a lot of cam and have relatively low manifold vacuum at idle. Most stock vacuum advance cans arent fully-deployed until they see about 15 Hg. Manifold vacuum, so those cans dont work very well on a modified engine; with less than 15 Hg. at a rough idle, the stock can will dither in and out in response to the rapidly-changing manifold vacuum, constantly varying the amount of vacuum advance, which creates an unstable idle. Modified engines with more cam that generate less than 15 Hg. of vacuum at idle need a vacuum advance can thats fully-deployed at least 1, preferably 2 of vacuum less than idle vacuum level so idle advance is solid and stable; the Echlin #VC-1810 advance can (about $10 at NAPA) provides the same amount of advance as the stock can (15 degrees), but is fully-deployed at only 8 of vacuum, so there is no variation in idle timing even with a stout cam.
For peak engine performance, driveability, idle cooling and efficiency in a street-driven car, you need vacuum advance, connected to full manifold vacuum. Absolutely. Positively. Don't ask Summit or Jeg's about it they dont understand it, they're on commission, and they want to sell "race car" parts.
__________________
I posted this awhile back. It's an interesting read.
Lazy is a term sometimes used to describe throttle response. I believe what he probably meant.
Distributor curve. I agree it is best to know when it stops advancing. Also two points is not enough to know the shape. It may be a two stage advance. It didn't ping at WOT, so it was never too advanced at full load. The advance may slightly retard at higher rpm. Depends on the ignition box and distributor. Since your not turning it much past 5000 rpm at this point, I don't think its that important.
It's likely the difference in timing between the two lights is the electronics. At higher rpm, the slower one will show up. Or if you ignition is multi-spark, who knows. Doesn't matter as long as its consistant.
I honestly think the lean mountain we are seeing is the throttle being squeezed on. AFR should go leaner with more throttle (load) until 70-90% full throttle, then it needs to go richer. ( On Holley type carb, that additional fuel is supplied through by "power valve" opening.)
See if the guys will let you do the driving next time you go.
First, do what they tell you. Then you'll know their method. Also more likely they'll be honored rather than offended by the request.So, if they WILL let me drive it, what do you suggest? Get it up to 3rd gear cruising at 2000 RPM and have them start recording immediately followed by me mashing the throttle to WOT? Do I hold that through 5300RPM (Don't HP and Torque cross at 5250?). I am open to your suggestions of what to do on the dyno (How I should make the pull)
