74 360 dart sport
New Battery ground wire top post mine has the original wire from 1974 Dodge Dart sport 360. it is in bad shape. it has the 2 wires what gauge should I get or is there a good source on here.
Probably one of the best sources these days would be a welding supply store.....they still use fine wire HD cables.good looking finding them in current so called parts stores. I
Tony will do you right!Thank you everyone for the advice. I am going to have ce auto electric supply build one for me. I also bought a new interstate battery.
How much for 30 in. Top post with a 12 in. 2nd lead that goes to the radiator support.I build them as well. Don't look stock/oem. Whatever length you like using high strand 1/0 welding cable.
