crazy 340
i aint sure but i think the Indy heads
at the end are cheaper when you buy them in kit
is it me or they are expensive
http://www.hughesengines.com/Index/...&level2=RWRlbGJyb2NrIFZpY3Rvcg==&partid=26914
I though Indy were expensive
Thought I saw another thread on these where an engine builder was talking about sorting out what rockers to use with these heads and that tti were making pipes to suit,but can't find the thread. Can anyone point me to it?
I have been waiting for a kit with heads rockers/shafts pushrods etc. that will be tested and good and durable. At a reasonable price. Then I'll buy a set. I have 2 sets of Indy T/A heads that make good power for my application.TTI should have the headers available in a few weeks. I didn't ask if it was going to be early or late August.
http://www.ttiexhaust.com/Category-ClassicHeaders/360W5ED/TTi360W5ED.htm
ok thanks . it gets hard to follow along at times.I believe that was in reference to the Victors.
A single shaft would be simple but here at Crower we like things that last and putting needle bearings on the rockers makes for just a better piece.
A single shaft would be simple but here at Crower we like things that last and putting needle bearings on the rockers makes for just a better piece. Plus it make adjustment WAY easier. Going to look something like this. I know its chevy but think mopar. Plus since Crower is almost a racing only shop mostly everything we make is made for tuneablity so changing rocker ratios while at the track is super easy. This is not that important for a drag racer but guys who go straight then turn left only to repeat again, this is important.
Yes but they are aluminum, so there is that.yes and the harland and t&d rockers have needle bearings
Worked for a Crower dealer, you guys,don't cut corners..... Still offering, the Pro 55 flat tappet option?A single shaft would be simple but here at Crower we like things that last and putting needle bearings on the rockers makes for just a better piece. Plus it make adjustment WAY easier. Going to look something like this. I know its chevy but think mopar. Plus since Crower is almost a racing only shop mostly everything we make is made for tuneablity so changing rocker ratios while at the track is super easy. This is not that important for a drag racer but guys who go straight then turn left only to repeat again, this is important.
Rob,knowing Crower: stainless .....And yours are made of ......
Any time frame for there appearance?
