harvenator
A fish called Wanda
I recently rebuilt a 273 and had a multitude of problems with carburetion and timing. I finally got it to run and fixed my timing issue with a new distributor. I ran it at about 2500 rpm for about 30 mins to break in the cam and drove it about 40 miles, with 18" flexpipe on the stock manifolds for some back pressure, to check for leaks and take it to an exhaust fabricator.
After i got the exhaust done, I drove it home and readjusted the valves.
Next morning I cranked it up and tried to drive it into town but about 8 miles down the road, after a few second boot to 4000 RPM, it started smoking.
I pulled over and found my breather cap gone and smoke coming from the valve cover.
I nursed it to AutoZone and replaced the breather, got it home and rechecked the valve lash.
What gives?
PCV valve feels as if it works (rattles and idle changes when it's pulled).
Wires weren't touched.
Rings weren't gapped but were installed properly.
Anyone have any ideas?
What gives?
