dazedand confused
I checked with the machine shop guy the engine has been decked!
Don't know but if you where to use a steel strait edge and sit it down on the gasket surface of the engine where the head sits with piston at top dead center the top of the piston will just touch the strait edge. I don't think 0.010 feeler gauge would slide between them?
So I got rid of the ticking under the valve cover by switching back to the sold factory push rods. Then I inspected the carb thoroughly and the floats where a little off and some how dust or some kind of filth got into the carb and moved through out the passage ways and some what clogged up the tiny little ports. So after carb and choke cleaner and back flushing everything and retighting bolts some I found a little loose the carb is running much better. Also I found a bad ground at the heat sink where my 4 prong ignition control module is mounted. Vehicle runs much better but still have an issue with timing ? I'm running the mopar performance distributor with performance curv.
Good.. you are back to where a factory engine was. Glad to hear you found those other issue... they all sound pretty common. Can you better describe the 'issue with timing' for us?Was able to get 130 psi each cylinder after leaving the throttle plates wide open like I was suppose to
