Mopar Fast Ratio Steering Linkage Kit
Upgrade your steering setup today with PSTs brand NEW Fast Ratio Steering Linkage Kit. PST had you Mopar Fans in mind when designing this kit. It will enhance the steering capabilities of your A,B or E Mopars. Our kit includes our Fast Ratio Pitman Arm, Idler Arm and the more robust 11/16 inner and outer tie rods ends. To tie the inner and outer tie rods together we have included PSTs solid Adjusting Sleeves. This kit will give you the best of both worlds, the steering ratio of a high performance AAR Mopar and the Heavy Duty steering components seen on the land yachts of the Mopar C bodies.
· The Fast ratio gives you quicker steering response.
· Solid Tie Rod Adjusting Sleeves. Machined from a solid block of hex steel. These reduce/eliminate the deflection seen in the factory sleeves
· Better Handling
· 11/16 solid adjusting sleeves that are normally found on the larger C bodies are now available for your A, B &E body Mopars
· Less turns of the steering wheel to get the wheels to turn a given distance.
· A plus for parking by having the reduced ratio.
· Works with Manual or Power Steering cars
PST, 1-(800)-247-2288, WWW.P-S-T.COM
Application:
1973-1976 A-Body Cars (Dodge Dart Sport, Dodge Dart, Plymouth Valiant, Plymouth Scamp, Plymouth Duster)
1966-73 B-Body Cars (Dodge Charger, Dodge Coronet, Dodge Super Bee, Plymouth GTX, Plymouth Roadrunner, Plymouth Satelite)
1970-1974 E-Body Cars (Cuda, Challenger)
Note: May not clear some aftermarket headers
