MOPAROFFICIAL
Oogliboogli
Nice job, Different animal.
What did the heads do?
110lsa, off the shelf cam, dual plane manifold......2400rpm between peaks.
Would need to know the whole combo to understand this one because I have seen in certain situations a really large spread and lower than expected peaks points to one piece of the puzzle being really out of wack effectively hamstringing peak torque/hp production.
115lsa....... 1700rpm between peaks
Imo, there’s no magic in the lsa. It’s about the whole combo.
Thats a nice 340 for sure and nice to see an engine that has a longer usable powerrange than all those underheaded oversized strokers we see so often nowadays.
For what its worth imho,big part of the short numerical spread between peaks often seen is due to the underheaded oversized strokers so popular today,and that is not to take anything away from this build,this seems like a very nice build.
Dwayne chose the cam for my 434 small block and peak torque is at 5000, peak hp at 6750.
I do have a few questions on the 650 carb, since I run a demon 650dp on my 340. This is an XP , the emulsion package could be different , which changes jetting req
It was 74 square jetted? Yes
Are you using any power valves? Yes
Downleg or annular boosters? Downleg, annular don't exist in a venturi this small off the shelf
1:1 or progressive secondary linkage? Progressive but that won't matter on a dyno
Thanks for any additional info.
Nice! Those mildly ported heads helped carry the mechanical cam a bit further than stock heads would by miles! I think the low amount of porting did a great job. How did it do under the posted test rpm? Is there an example around 3K done?
I know the small single plane doesn’t take so well that low.
Just wondering.
As we can see from the dyno sheet the engine is not done yet at 6900RPM since power is still climbing... did you take it any higher than 7000 to see what the power curve would do? Or not worth it for a measly 2Hp more and more stress on all parts?I wanted to build a 340 worthy of the legendary status they have due to their eagerness to RPM
IMHO... points to knowing the application needs first and then combining parts to get what you want. Big breathing and smaller, wide LSA is gonna compromise peak HP but is gonna spread the usable torque band. In some uses, where you never can put big peak HP to the ground, and don't have a 10 speed transmission, this is the best outcome. So there is no one 'best formula', just the best for application ABC....Not saying there is any magic in the LSA but I am saying I like to use it to get what I want.
Also saying it is not always wise to go to a narrow one especially in the case of these 4" crank with OEM heads deals.
I do agree with you however--the whole combo. J.Rob
.....there is no one 'best formula', just the best for application ABC....
Do you recall what cam and head combo were part of this build.110lsa, off the shelf cam, dual plane manifold......2400rpm between peaks.
Post 127 & 138Do you recall what cam and head combo were part of this build.
Nice work
Thanks
Look at the tq drop off point...If you were shifting that motor it would be earlier than the hp peak rpm , or feel wrung out with the tq dropoff. Also has an electric water pump on it freeing up that top end .Nice! Those mildly ported heads helped carry the mechanical cam a bit further than stock heads would by miles! I think the low amount of porting did a great job. How did it do under the posted test rpm? Is there an example around 3K done?
Just wondering.
