I wouldn’t put “Quaker Sludge” in my worst enemy’s car. I bought a 1970 ford maverick from my dad for a first car. He was a fanatic about changing oil. When I tore the straight six 300 engine apart to modify it the inside was all waxed up. That crap is junk.
I think I read recently that modern oils are "saturated" with additives so if you try to add more, they don't dissolve and eventually end up separating out and collecting at the bottom of the sump.STP was an additive that goes back decades, when oils were not as good as they are today.
In my opinion, it is foolish to add additives to todays oils. They have lots of 'packages' added such as detergents, dispersants....& ZDDP & you risk upsetting the balance of those additives.
I've heard the exact opposite by a famous Pontiac engine builder Nunzi Romano Brooklyn NY.Quaker State? No way !!! Have you ever seen the inside of an engine that ran Quaker State? Not pretty... For me it is Pennzoil 10w-40 with a can of STP which contains ZZDP at every oil change. Been running this combo for yearssss in my current HiPo 340 and never have had no issues.
I now believe full synthetic will harm an old engine that needs High viscosity.Really ANY performance engine should use a racing type oil with plenty of zddp or similar additive package. With strokers you have alot of thrust on the cylinder walls and good oil will prevent any scuffing or premature wear from happening.
I agree with TD, roller or not your quality components NEED quality oil with plenty of scuff additive!!
Brian
I decided to use the regular conventional GTX 2050 with trick flow sink additive because that oil right there is a blend. I made the mistake of putting VR1 in my old engine I don't think it hurt it. But it immediately found a couple of leaks because it's full synthetic. It also does not have detergent so it got dirty within 2 weeks. Not only do we need zinc but we need a detergent oil. The famous Pontiac engine builder told me back in the '80s for my SD455 to run Quaker State 20-50 but not racing oil.I just changed the oil in my Duster this morning and used this. It was about $8 a quart at AutoZone. I saw it a couple days later at Walmart a little cheaper, but only 1quart on the shelf.
Not only is it a big deal for us old performance engines to have the old Pennsylvania mineral style crude but it's a big deal to have the detergents. I looked at All Mileage I know it's a blend. And I'm no expert you know that but I've studied about 40 hours the last couple weeks about viscosities. I'm now know I'm looking for conventional with detergent and it's hard to find because most of conventional now is like a blend. It's a blend and it's got additives for seals and stuff which I don't trust.@Dannyd
I spent 32 years in the automotive lube business. I just counted eight untrue statements in your two posts. I don't have time to go through them one by one. But that's OK, I'm not going to try to change what you believe, just try to help you get you what you want.
Quaker State has mostly moved on from obsolete products. I wrote to their tech email address when they introduced the All Mileage oil a year and a half ago. I asked the about the zinc and phosphorous content. They didn't reply.
From what you say, this is what you want. Or as close as you're going to get at a reasonable price. Good luck!
[/URL][/URL]
I know I've already stated this but back in the '80s Quaker State was top of the line. Famous engine builder told me he's never taking a motor apart that's been running quicker it's whole life and been dirty. He built me a 500 horsepower engine and told me to run Quaker 20-50 but not racing oil. My friend talked me in to puttingin VR1 in my engine which was totally wrong and also it got dirty both times within 2 weeks. For me I'm going to find real conventional that's got detergent in it ( most commercial is a synthetic blend now) and then I will ad an additive. I'm just going off experience and what I've been reading. I'm no expert or claim to be but I care about my engine.Quaker State? No way !!! Have you ever seen the inside of an engine that ran Quaker State? Not pretty... For me it is Pennzoil 10w-40 with a can of STP which contains ZZDP at every oil change. Been running this combo for yearssss in my current HiPo 340 and never have had no issues.
Just because it looks thin cold Is not a bad thing. Start up flow is a good thing.
How does conventional oil look at 220 degrees I'm willing to bet it's pretty thin
